Carputer / CarPC wiring help
Old May 27, 2007 | 03:39 PM
FamousG's Avatar
Hey guys, just picked up a carputer from another member on the board. Everything should be ready to go, just need to be wired up. Does anyone have instructions or links for this? The main problem I'm trying to figure is how to supply power to the carputer. It came with all the wires pictured:
The RED wire is 8 gauge power wire which has a crimp connector on one end.
The smaller BLACK wire is 8 gauge ground wire which has a crimp connector on one end.
The larger BLACK wire is 4 gauge wire. No clue what this does.
The GRAY wire looks just like a USB printer cable. The carputer was originally sold with a Xenarc monitor which I didn't buy. Maybe this was used for that?
Also, I have a power inverter, is there a way I can retrofit this to use AC/DC? It would be nice to be able to switch from a carputer to a standalone computer.
Old May 28, 2007 | 08:23 PM
DIGItonium's Avatar
I think it already has a PSU (M2 ATX), and you supply power through that 8-pin connector on the right. You'll need to get the pin-out for it.
Old May 28, 2007 | 10:22 PM
ScubaSteve312's Avatar
ask the member *cough* flip22 *cough* who you bought it from and ask where to get directions
Old May 29, 2007 | 03:02 AM
FamousG's Avatar
Yeah, figured that out, trying to get ahold of that because it was missing. Still need directions for install. Someone with a carputer please chime in. Do I wire it to ignition, and if so how does it know when to shut down like a normal computer?
Old May 29, 2007 | 03:03 AM
FamousG's Avatar
Already did. He's trying, but the guy he bought it from is no longer a member here.
Old May 29, 2007 | 12:58 PM
KPierson's Avatar
I hooked mine up to the main 12vdc wire going to the ignition switch, and then to the ignition wire also. There were two wires needed on my M2 power supply.
I'm running a very small setup though, so I used ~18ga wire.
It looks like your setup is designed to go directly to the battery. Make sure you fuse properly it at the battery, otherwise it can be a fire hazard.
Old May 31, 2007 | 02:02 AM
FamousG's Avatar
The power supply has 5 wires that lead to the pin-out.
Red - Power
Black - Ground
White - Ignition?
Small Red - LED light
Small Black - LED light
I think it's pretty basic, but I just wanna make sure so here's some noob questions.
I went and picked up the pin-out connector at Fry's today along with an AC receptable which allows the use of a typical 3-prong outlet plug. Anyone know how I can make this work? Do I wire the power to the left or right prong on top or both? I think I might pick up another pin-out connector so I can switch from using it in the car and in the house.
Does the pc shut down like a normal desktop or do they normally have some type of software that let's it know to shut down properly when you turn the ignition off?
Anyone know the the 4 gauge black cable that was included is for?
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
prinny
Nov 22, 2015 11:07 PM
BfloG35
Oct 16, 2015 05:22 PM
9tray turbo
Sep 29, 2015 10:22 PM
the93owner
Sep 28, 2015 10:37 PM
