deading material for subs
Old Jan 10, 2004 | 12:44 AM
ericinmia's Avatar
Re: deading material for subs
i just bought a bulk pack of extreme from sounddomain.com...
36 square feet, it should be sufficient.
i'll tell you later in the week once i install it:
trunk, doors, floor, etc.
-Eric
'03.5 Silver/Black | Prem | Perf | Aero | Stillen Hi-Flow | Z -Tube | Grounding Kit | Nismo Oil/Radiator Caps | Solid Allum Pedals | Diamond Matts | Tints | Valentine1 | Hide-Away License Plate!
Old Jan 11, 2004 | 04:06 PM
acurasixty's Avatar
I had the front two doors dynamatted and the rear deck. IT helped out so much in the doors, but the rear sub still sounds like crap because it is the sub that is making the distorted sounds and the dynamat helps amplify it. It sounds better though. I also took the black plastic baffle off of the bose sub and put alittle piece of extreme dynamat in there and put it back on. That seemed to help alot more than dynamatting the rear deck.
g.spot
May 9, 2016 10:54 PM
MrIP35
Audio/Video/Electronics
Nov 8, 2015 10:47 AM
dcsbh1
Oct 1, 2015 03:15 PM
eljefe7070g35
Sep 11, 2015 09:28 AM
