ipod integration w/ 2006 Sedan 6disc in-dash changer (non-Bose)
Old Jun 9, 2007 | 05:00 PM
etmaestro's Avatar
Based on what I've read in the forums, there's no auxiliary input for satellite or external CD changer on my unit. I'm not at a place to replace HU so it sounds like I'll need to tap into the antenna and use an FM device as a stop-gap.
Any recommendations on decent units for this? Also, does anyone know what type antenna interface is on the in-dash 6 Disc changer (non-Bose)?
Thanks in advance for your help.
Old Jun 9, 2007 | 11:14 PM
4 Door Skyline's Avatar
the USA-Spec PA11-NIS should work for you, thats the ultimate ipod solution
Old Jun 10, 2007 | 03:01 PM
etmaestro's Avatar
Thanks for the scoop. They list the following note:
Note: The PA11 iPod interface uses your receiver's CD changer port. If the vehicle has an existing CD changer, it must be disconnected.
* Works only with factory double-DIN (DD) radio equipped with "CD/CHG" button
Being that mine is an in-dash CD changer and I don't have the "CD/CHG" button on my HU, does this mean that I can still use this to hookup the iPod and I simply lose the control capabilities from the HU? From the pictures I've seen, the only PA11 interface to the HU is through a harness designed to plug into an optional CD changer port which mine does not have.
Thanks.
Old Jun 10, 2007 | 11:28 PM
yea its made for the external changer input, you retain all factory capabilities, including the in-dash 6 disk changer. And also it lets you change tracks from the steering wheel, another plus in my book, as well as giving you a set of auxiliary rca inputs for whatever you can think of (dvd player, external sat radio, etc.)
Old Jun 11, 2007 | 03:27 PM
g035sedan's Avatar
i have the 05 but we have basically the same car and our stereos are the same. read this.
https://g35driver.com/forums/showthr...highlight=ipod
dpark0223
Sep 11, 2015 02:17 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
BlackGee35
Jul 21, 2015 07:24 PM
