Will this work out?????
Old Jun 13, 2007 | 03:44 AM
digital1986's Avatar
http://www.cdtaudio.com/hd42_cdt4.htm
Its the Hd-62 set (First one) I can get a good deal on them.
Will those comps install in my 03 G Sedan no problem???
I will need these right??
These adapters? or does someone have better to buy from?
THANKS!
Old Jun 13, 2007 | 08:35 AM
digitalhifinet's Avatar
The G has a pretty deep mounting spot for 6.5" drivers, so you should probably be fine. As far as the adapters go, check on the cutout hole required for those CDT's, because the adapter you listed is 5 1/2", and you would need the CDT's to have a cutout hole of ruffly that. You don't really need to buy those adapters, you can make your own if you have a router.
Old Jun 14, 2007 | 02:13 AM
ya thats what I was told. I guess I can have the install making something so the speakers fit. Other than that everything looks like it should work (Ya, I still need to find a amp to power them )
Old Jun 14, 2007 | 09:04 AM
Gilley's Avatar
The speakers will fit without the spacer. The purpose of the spacer is to put the speaker out to the door panel so there isn't a big gap there. You should get better sound that way.
Old Jun 14, 2007 | 02:37 PM
Sweet!! I will order them now!
arora_g35
Apr 16, 2026 02:52 PM
obender66
18 Inch
Mar 13, 2016 12:20 PM
Big C
19 Inch
11
Oct 3, 2015 05:11 AM
JMSABO
Aug 4, 2015 11:58 AM
attarday
Jul 15, 2015 04:03 PM
