putting wires through
Old Jan 12, 2004 | 09:30 PM
TEKxBiggieCx's Avatar
can any tell me where to run power wire through the firewall. Im trying to install a system, but I can't seem to slip the power wire through anywhere.
Old Jan 12, 2004 | 09:39 PM
Meatshackle's Avatar
Deep Sea Moderator
Re: putting wires through
https://g35driver.com/forums/showfla...sed&sb=5&part=
Russ
Black 6MT Coupe
Jax, FL
PS2 and Headrest thread
Old Jan 14, 2004 | 09:55 AM
RacerX's Avatar
When I ran wires for my amp and DVD system, (one 4 Ga plus a couple of 12 gauge) I did NOT need to puncture the grommet on my '04 Sedan. Once I removed all the gummy tape and sealant, the grommet had a 5" long rubber sleeve attached to it. All I needed to do was stretch this a little and it was easy to fit the extra wires in, even the 4 Ga amp power. You must make sure you put the gummy tape and sealant back the way it was when you're done. But, I do feel that this method gives a better chance of a weather-tite seal than puncturing the grommet and adding sealant.
04 G35s 6MT BS Aero Kit/Nav/Prem
Warning: Objects in Mirror Are Losing!
Old Feb 26, 2004 | 03:55 AM
Spicedog's Avatar
Much thanks to the author of these instructions!! I would have never found that on my own. FYI for you coupe owners the instructions are exactly the same. Another note is the grommet is big with lots of wires going into it. I was looking for a small grommet with a couple of wires and missed the obvious great big one where the gob of wires was.
Old Feb 27, 2004 | 06:07 AM
SixgearSedan's Avatar
I ran a 2 gauge through the grommet to a distrobution block in the trunk. I placed my 100 amp fuse block just inside the kick panel cover. I love my 1600 watt DVD entertainment system.
Old Mar 4, 2004 | 09:19 AM
G3NUI5's Avatar
G3NIU5!!
brownie
Nov 25, 2015 12:50 AM
whattf
Sep 1, 2015 07:42 PM
zcherub
Aug 30, 2015 05:04 PM
Jadenkid22
Jul 14, 2015 12:33 AM
