v35 AC Controller pix
Here are some pictures of the AC controller and the button that needs to be switched with stock DCC button.
Re: v35 AC Controller pix
Notice that the "Dual" does not have a green press button like the other buttons.
tig488 or g35mt, this green button is the one that has to be removed from old AC controller and resoldered onto new AC controller board right?
Here is a pix of what my dash looks like so far....
I will run the RCAs tonight and probably do the dash switch this weekend.
BTW, this is what the v35 AC controller looks like before I removed the "Dead" DCC button...
correct that is the button that needs to be swapped, the setup looks good
03 BS/Graph 6MT Prem Cp
19" GunM TE37 275/30 MPSports
kg/mms,cambers,cusco sways,injen int/exh,Alpine/JL/Stinger,din master
thanks for the quick reply....don't know what I should do though, remove the HVAC board and drive around without ac or stereo for the rest of the week so I can work on the removal and resolder of DCC or just do it all one time when I do the entire switch/swap...?
looks awesome
bout how long do you think it took you to desolder and resolder and transfer the button and stuff over
Daniel
5AT Coupe / DP / Premium / Aero / Clear Bra / 5% Tint - 30% Windshield / Ground Kit / Clear Corners / Shock Sensor / L.E.D. Hood Lights
Daniel
