Had this problem with your Escort Passport?
Old Jun 20, 2007 | 05:15 PM
CalRSX07's Avatar
My Escort Passport 8500 x50 radar detector does this thing where it will all of a sudden shut down and restart itself immediately (and sometimes doesn't restart itself unless I take it out and plug it back in).
Has anyone had this problem? I want to get Invisicord so I can mount it up on my mirror and get rid of the coil cable... so basically I want to know if this is a problem with the detector, or maybe just with the wire. If it's a problem with the wire, Invisicord should fix it.
Anyway-- anyone deal with this before and know what it might be?
Thanks!
Old Jun 20, 2007 | 05:32 PM
savefatkids's Avatar
i had the same problem..the plug just gets loose and thats y it turns off. when i got my invisicord i had no problems with it turning off. try it out. its less than 10$
Old Jun 20, 2007 | 10:19 PM
ltrrtl218's Avatar
mine goes through phases where it says service is required...i just unplug it then plug it back in and then its fine. i dont know why it would need to be serviced
Old Jun 21, 2007 | 07:04 AM
g35rcr's Avatar
does your direct hardwire have a built in fuse??? i fried my x50 a while back because the power cord had no fuse...
Old Oct 30, 2008 | 12:56 PM
CalRSX07's Avatar
also, for a long time my x50 has been doing this thing where it will pop up a laser warning whenever i go WOT... it's happened enough times with this pattern that i know there's no laser! just when i floor it, it bleeps LASER!!! so annoying.
also, it goes through phases where it says service required.
Ka-band still seems to work OK which is whats important, but does anyone know whats up?
Thebaws11
Jul 2, 2021 11:36 AM
G35xdriver04
Nov 7, 2015 08:31 PM
itgogitrev
Sep 23, 2015 07:08 PM
mattdg35
Sep 14, 2015 11:28 AM
