4awg through firewall
Old Jun 26, 2007 | 01:56 PM
lancer's Avatar
Where did you guys put your power wire through your firewall... I'll be taking the plunge pretty soon but it seems that the firewall might be the biggest pain of the whole install. I have about 18 feet of 1/0 awg sitting around but decided to go with 4awg for an easier install... unless there is some magic conduit for 1/0awg wire in the G
Forgive me for the rather common question but I didn't find any pics or threads regarding getting through the firewall. Any help is appreciated.
Old Jun 26, 2007 | 01:59 PM
Hi-TechG35's Avatar
I removed all of the plastic that houses the battery and used the hole where the rubber cover is. afterwards make sure you reseal it with some silcone to stop any leaks or water from getting in.
digitalhifinet's Avatar
There is a large rubber grommet under the battery cover near the top of the fire wall that is plenty big to slit and slide the wire through.
Old Jun 26, 2007 | 02:01 PM
erdog's Avatar
I resealed it with some high temp liquid electrical tape.
Old Jun 26, 2007 | 02:04 PM
redlude97's Avatar
I didn't like the idea of cutting into the grommet, so I unwrapped all of the electrical tape that seals the wire bundle to the grommet, inserted my 4awg line, filled with liquid electrical tape, and then retaped the entire grommet. Can't even tell its not supposed to be there
Old Apr 5, 2008 | 05:09 PM
ttrank's Avatar
Grocery getter
I made a new hole down lower behind the battery and used a 0ga grommet for my 0ga run.
Old Apr 5, 2008 | 07:24 PM
Meatshackle's Avatar
Deep Sea Moderator
I went with the factory hole by the battery. Definitely reseal it because that's where all of the water from the windshield goes. I think I was the first to discover that while my ECU was taking a bath. That could've been bad.
If you drill a new hole make sure you know what's on the other side. That area is full of all kinds of expensive stuff.
Old Jun 2, 2008 | 09:20 AM
obsdnoblivion's Avatar
All you guys have coupes? Is this grommeted hole in the same place by the batter on the 04 Sedan?
Old Jun 2, 2008 | 06:43 PM
Gilley's Avatar
Yes, the 03-06 sedans have the same rubber piece. Make sure you seal around it with silicone after the wire is passed through.
BradMD_96
Oct 6, 2015 09:31 AM
G352NV
Apr 8, 2006 01:23 AM
Zman
Aug 31, 2003 01:20 PM
