Sirius in an '03 Coupe?
Old Jul 8, 2007 | 06:48 PM
cor72vette's Avatar
I have an 03 Coupe with the Bose system. Is it possible to make the Bose HU receive Sirius? And if so, will it use the Bose's display? TIA!
Old Jul 9, 2007 | 12:45 PM
Gilley's Avatar
If you have a SAT button on your radio you can connect an OEM Sirius receiver to it. You may need to buy the wiring harness though, as not all 03's came prewired for SAT and non did if they don't have the SAT button.
The Bose HU will display limited Sirius and XM information.
Old Jul 9, 2007 | 05:41 PM
cor72vette's Avatar
Thanks for the info. My Bose does have the SAT button. I've been digging through the forums trying to get this info... Are the OEM Sirius receiver and wiring harness readily available?
Old Jul 9, 2007 | 08:57 PM
Gilley's Avatar
Everything G35.com has what you need, including the wiring harness if you need it. http://www.g35parts.com/9083/osc/pro...roducts_id=284
since you have an 03, check the last 6 digits of the VIN to see if your car comes prewired. Coupe VIN: 210827 & higher are prewired.
Old Jul 9, 2007 | 10:00 PM
cor72vette's Avatar
Thanks for the help!
djreinx
Engine - Electrical
Dec 10, 2015 01:48 AM
Th611
Oct 27, 2015 03:48 PM
Kal Hamm
Jul 24, 2015 08:55 AM
