Radar Hard Wire Questions
Old Jul 22, 2007 | 03:15 PM
Drtybrd61's Avatar
Question Radar Hard Wire Questions
Hey guys,
I was thinking about getting a radar detector and wanted to hard wire it to the rear view mirror. Here's the problem, the mirror that I have does not have the homelink/auto dim on it. It's just the base model rear view mirror. My question is, can I still do the hard wire using the Invisicord or do I have to have the rear view mirror with homelink?
if they answer is NO, you can do it without the homelink mirror, then I'm good, however, if I need to get that, how much should I expect to pay for the homelink mirror and how much to have it installed (if it's something I can't do myself)?
thanks in advance!
Old Jul 23, 2007 | 09:34 AM
Gilley's Avatar
I just bought the hard wire kit for my detector, connected it to s switched fuse at the fuse panel, and ran the power wire up the A pillar under the cover and tucked it under the headliner. To the mirror. I actually started at the mirror so all the excess wire would be at the kick panel.
Old Jul 26, 2007 | 11:22 AM
Drtybrd61's Avatar
see, i really don't want to run a wire all the way through the interior. i just wanted to use the invisicord.
anyone else know?
Old Jul 26, 2007 | 06:49 PM
elvisin3d's Avatar
Gilly, Could you post some pics of the line you hook into in your fuse box...
Im thinking of just running the line through the pillar....
Old Jul 26, 2007 | 08:21 PM
Gilley's Avatar
I just located a wire that was already coming out that turned off with the key.
Old Jul 27, 2007 | 03:43 PM
elvisin3d's Avatar
Any paticular color? I know I just need to one with a wire that doesnt stay hot all the time...Im guessing you just did the guess and test method?
Old Jul 27, 2007 | 04:01 PM
JOKER's Avatar
CLUB MODERATOR
I bet that you wire harness is same as all the other Gs the only diff is your mirror. So I suggest look under the headliner for the connector for the mirror and hook it up through that.
Old Jul 27, 2007 | 04:06 PM
Gilley's Avatar
I used a test light at the fuse panel. Littelfuse makes mini fuse panel taps that plug into the fuse box in place of a fuse. It provides protection to the main fuse and adds a wire pigtail that is also fused (on a separate fuse) that you can then connect to the device of your choice.
Old Aug 17, 2008 | 12:26 AM
Jamaica2G's Avatar
Good call Gilley, that is a nice little schindig -
I know I'm digging this up, but did you have a Homelink mirror from factory, Gilley?
Also, with the homelink mirror, does it have to remain on a hot wire to maintain/remember the signal? or can I attach that one to an ignition-switchable wire as well?
Thanks Gilley and everyone else!
Adrian
Old Aug 17, 2008 | 02:19 PM
Gilley's Avatar
Yes, I have a Homelink mirror. I decided to run the power from the fuse panel so I could put the remote control on top of the steering column so the alert light is more visible.
Old Aug 17, 2008 | 05:29 PM
kenchan's Avatar
after about a year of using the v1 with the hardwire i could not find the
'right' location on the glass.. ended up using the coil harness and mounting
it right above the cluster on the glass. bestest position yet.
not fond of the bulky mirror adapter either.
Old Aug 18, 2008 | 09:38 PM
SgtChung's Avatar
Gilley did you use 10+5 on the for the seperate fuse or can you just use 10 and connect it to the 10 A spare
Old Aug 18, 2008 | 09:47 PM
Gilley's Avatar
I don't remember what fuse I used, but a 5 amp would be plenty. Check the fuse rating in the plug in power supply and use at least that rating.
Old Aug 28, 2008 | 09:30 PM
WNClivin's Avatar
Good info here.
When you take apart the radar detector's cigg plug, which wire is positive and which is negative? The one leading to the sides or to the tip contact?
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
whattf
Sep 1, 2015 07:42 PM
carid
Group Buys-Vendor
Aug 7, 2015 12:17 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
.cakestar
Audio/Video/Electronics
Jul 17, 2015 08:22 PM
