Wire harness adapter
Old Jul 23, 2007 | 11:29 AM
jayhoe's Avatar
What is the difference between the regular one and the one with RCA outputs?
http://www.crutchfield.com/S-XP7CV1q...7550&s=0&cc=01
vs
http://www.installer-parts.com/by_item.php?it=70-7551
which would be best if I'm just adding a head unit now but might change speakers/amp at a later time?
Old Jul 23, 2007 | 01:32 PM
Gilley's Avatar
Do you have the Bose system?
digitalhifinet's Avatar
The one with RCA's allows you to hook up your aftermarket H/U to the Bose Amplifier using RCA's. You could do this with the other one as well, but you would have to make your own RCA connector. I would get the one with RCA's if you are getting a high quality H/U that has at least a 4V pre out voltage. Once you replace the amplifier, you probably won't need the speaker outputs behind the dash.
Old Jul 23, 2007 | 02:28 PM
Gilley's Avatar
The OEM Bose HU signal to the Bose amp is about 2 volts, so you may have to be careful with the volume level of your HU since you can't adjust the gain on the Bose amp is you send speaker level signals to the Bose amp. You may need a LOC.
Old Jul 23, 2007 | 04:38 PM
jayhoe's Avatar
sorry, yes i do have the Bose. I'm getting the kenwood ddx8019 which has 5v pre out voltage. So what I am understanding is that I should get the harness with the RCA cables if I plan to possibly later on remove the Bose amp and replace speakers?
Old Jul 23, 2007 | 04:44 PM
jayhoe's Avatar
Also, I plan on putting this in for now
http://www.crutchfield.com/S-XP7CV1q...SLC4&s=0&cc=01
still compatible?
Old Jul 23, 2007 | 06:38 PM
Gilley's Avatar
You don't need the harness with the RCA plugs. Your Kenwood has 3 sets of RCA outs already. I think you will need some interface like the PAC OEM-1 to go between the Kenwood and the Bose amp, or you may be able to use the Kenwood's RCA outs and connect them to the Bose amp at the wiring harness. I've never done the aftermarket HU to Bose connection, so maybe someone that has done it can help.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
prinny
Nov 22, 2015 11:07 PM
the93owner
Sep 28, 2015 10:37 PM
vamarris
Sep 26, 2015 12:56 PM
