hooking up subs to stock deck
Old Jan 24, 2004 | 10:01 PM
GThirtyFive604's Avatar
I wanna hook up 2 alpine R 12's dvc 4+4 ohm subs to the stock deck with an v12 expert amp MRV 1505
my question is would i need get anything extra to make this set up work? and can i keep my stock sub still running to?
thx in advance
IVORY PEARL G35 SEDAN
Old Jan 25, 2004 | 11:42 PM
Re: hooking up subs to stock deck
anyone with info ?
Old Jan 25, 2004 | 11:58 PM
ericinmia's Avatar
what do you mean exactly.... custom mounting them to the rear deck? if they are too heavy, or create to much strain you might have a problem... and if they are not free air speakers you'll have a prob... and are you going to cut holes bigger for them??
-Eric
'03.5 Silver/Black | Prem | Perf | Aero | Stillen Hi-Flow | Z -Tube | Grounding Kit | Nismo Oil/Radiator Caps | Solid Allum Pedals | Diamond Matts | Tints | Valentine1 | Hide-Away License Plate!
Old Jan 26, 2004 | 03:27 AM
i'm gonna have a box for it in the trunk
Old Jan 27, 2004 | 12:22 PM
pestilence's Avatar
I have two solo baric L7s in the trunk..
what you need to do is get a splitter and connect it to the back of your head unit and split the signal so you get preouts (you dont have to do that if you already have a sub in the trunk) .. then from there just take it to your amp.. and wire your subs..
cmesidewayz
Sep 29, 2015 09:28 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
Frostbite91
Aug 2, 2015 04:59 PM
