Eclipse AVN install NEED HELP
Old Jul 28, 2007 | 08:38 PM
pixmerollin's Avatar
Got the dd kit and eclipse avn5500 mounted everything, ran all the wires. I have a 04 Coupe non-bose. Got a harness from Al & Ed's and plug it in but no power goes to the unit. Tested the unit on my brothers accord, works fine. I think the harness is not the right one, the guy at Al & Ed's says its for a 350Z and it should work. Also I don't have the antenna adapter is this a problem? Please help......
Old Jul 29, 2007 | 02:55 AM
caskyline's Avatar
Former Vendor
The ground wire on a Nissan adapter does not go to ground. You need to ground the stereo to the chasis.
Old Jul 29, 2007 | 12:58 PM
sfgr415's Avatar
yes...ground the stereo to chassis. the antenna acts like a ground so that may be why it isnt working since you dont have it connected.
Old Jul 29, 2007 | 04:52 PM
Thanks for the help, I figured that I needed the antenna I just ordered one. Also does anyone know where the G35's computer is so I can tap into the speed signal and where should I tap to get the reverse signal..Thanks.
R350k5
Oct 1, 2015 08:41 PM
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
