"No Sat" - satellite radio issue
Old Aug 4, 2007 | 11:46 AM
DieselCasa's Avatar
DCASA
2 Days ago, i turn off my car, run inside gas station, turn car back on and the radio displays: No Sat. Everytime you hit the sat button it displays No Sat. Like its not there. When it has signal problems it says no signal, aquiring, etc... Btw i have a factory sat that has been active and working since i bought the car in 03. This is real strange, its almost as if the car thinks there is no satellite.
Anybody have any solutions / suggestions?
thanks
p.s... did several searches and came up with nothing
Old Aug 4, 2007 | 12:23 PM
filanj's Avatar
I would take a look at the receiver in the trunk. Just take everything out of your trunk: carpet, bottom holder, left plastic bank, (unscrew the tire mount nut so you can move the tire to the right side.) There is a small nut down in the spare well on the left side holding the plastic molding in place. Take the nut off and remove the molding. The receiver will be under it. Double check to make sure the harness is in there securely and that no rips are in the wires.
Old Aug 4, 2007 | 12:36 PM
da mayor's Avatar
if it's a dealer or factory installed option you are covered for 4yrs/60k miles-- sounds like the dealer can help
Old Aug 4, 2007 | 12:51 PM
fbw5595's Avatar
Try this:
https://g35driver.com/forums/audio-video-electronics/109116-serious-sirius-problem.html
If it does not work, go to the dealer.
If your covered, there is no reason not to go to the dealer.
Old Aug 4, 2007 | 02:48 PM
denverinfiniti's Avatar
Its the control unit in the trunk. Take it to the dealer and have them replace it. We see that alot here on the older recievers
Old Aug 6, 2007 | 08:36 PM
DieselCasa's Avatar
DCASA
I hate going to the dealer. I gained access to the unit through the trunk, did what you guys said, unplugged and pluged it back in. That did the job!
Thanks!!!
Frostbite91
Aug 20, 2015 07:20 PM
Phalanx
V36 Audio, Video & Electronics
Aug 10, 2015 11:31 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
kd03g99
Jul 30, 2015 11:24 AM
