HELP! Bad ground?
Old Aug 12, 2007 | 01:30 PM
jayhoe's Avatar
HELP! Bad ground?
Ok, so I took my aftermarket radio out to make some minor adjustments, and when I put it back in - no workie. After some multimeter testing, it seems I am not getting a voltage drop between the ground and the +12V from the harness. Between a metal part of the car and the +12V of the harness works like a champ though. How or what could have caused this? Should I simply wire my ground wire to a metal part or is there something more sinister lurking behind the dash?
Old Aug 12, 2007 | 07:54 PM
digitalhifinet's Avatar
In my car the GND wire on the wire harness adapter did not actually go to ground. I just wired the GND on the radio harness to a ground point I made myself. Try this, and if every thing is hunky dory, you should be fine.
Old Aug 12, 2007 | 08:23 PM
jayhoe's Avatar
Thanks, that's what I ended up doing. Works great now, but I'm not sure how it went wrong in the first place.
Vqalexisz
Oct 14, 2015 12:48 AM
Adon
Sep 22, 2015 03:56 PM
toadfire
Sep 21, 2015 07:15 AM
reaper76
Sep 20, 2015 11:59 AM
JustinMKN1
Sep 18, 2015 03:40 PM
