Hooking up Bose Sub to aftermarket amp
Old Jan 29, 2004 | 04:41 PM
RacerX's Avatar
Just curious; as I haven't decided what I want to install for a sub-woofer, (but I have bought a JL Audio 300/2 amp to power it!) can I hook up the JL amp to the stock Blose sub without risking damage to the amp? I have 4 component sets and another JL amp (300/4) for the doors, so I'd just as soon scrap the Blose amp.
04 G35s 6MT BS Aero Kit/Nav/Prem
Warning: Objects in Mirror Are Losing!
Old Jan 29, 2004 | 08:45 PM
SixgearSedan's Avatar
Re: Hooking up Bose Sub to aftermarket amp
Yes you can hook up an aftermarket amp to the factory sub, but the sub is a very poorly made sub and will distort the sound or blow if you put to much power into it. The entire depth of the sub from the top to bottom including the magnet is about 2". I would not be surprised if it blows at a 100 watts.
Old Jan 30, 2004 | 10:55 AM
RacerX's Avatar
I guess I'll have to keep the gain on the amp way down until decide what sub to get. I really need to remove all the trim from the rear deck and take a close look at everything under there to see what will fit, as whatever I do, it will be mounted on the rear deck, not a seperate box. Hopefully, I can figure out a way to use the rear deck location and still use an enclosure; there aren't too many options for free air subs.
Old Jan 30, 2004 | 01:57 PM
docmassage's Avatar
I'm curious, where is everyone installing their amps?
Old Jan 30, 2004 | 04:58 PM
RacerX's Avatar
<hr></blockquote> In my sedan, I plan on mounting my two JL amps (a 300/4 and a 300/2) vertically on the rear of the back seat; one on each side of the pass through. JL is not too thrilled with this orientation as far as heat dissapation is concerned, but I NEED my pass through for hockey sticks and skis. One of the main reasons I didn't go for a larger sub amp like the 500/1 was that it's too long to mount in this way; I'd have to give up the pass through or some other area of the trunk.
Old Jan 31, 2004 | 11:46 AM
jimmcrae's Avatar
Where are you tapping into for the amp? I have a sedan, regular stereo, not premium. Doing components, amp and sub. Thanks.
JG_G35
Apr 29, 2016 04:46 AM
nissandrifter32
Dec 22, 2015 04:28 PM
alessandro
Oct 8, 2015 09:29 AM
JoeMac
Sep 28, 2015 12:28 AM
JustinMKN1
Sep 18, 2015 03:40 PM
