wiring diagram for remote starter alarm
Old Aug 18, 2007 | 08:14 PM
MyLilBlkG's Avatar
Hi, does anyone happen to have a wiring diagram for installing a remote starter alarm system. I'm trying to get my compustar remote starter installed. but have no clue where the wire goes in our car.
any help would be great
thanks
Old Aug 19, 2007 | 01:12 AM
KPierson's Avatar
What year is your car?
Old Aug 19, 2007 | 01:38 PM
MyLilBlkG's Avatar
it's an 04 coupe, should have mentioned that earlier sorry.
Old Aug 19, 2007 | 01:44 PM
KPierson's Avatar
12volts - white/blue @ ignition harness
starter - white/red or red/white @ ignition harness
2nd starter - white/gree @ ignition harness
ignition - black/red @ ignition harness
accessory - white/black @ igntion harness
keysense - black/pink @ ignition harness or BCM
power lock - yellow @ driver door module in door
power unlock - lt. blue (double pulse) @ driver door mdoule in door
lock motor - purple @ BCM
unlock motor - yellow @ BCM
disarm defeat - white/blue @ BCM
Parking lights (+) - red/blue @ driver kick, harness to rear
door trigger - Yellow (dr), pink (pass) @ BCM
Dome supervision - purple/red @ BCM
trunk pin - red @ BCM
hood pin - lt. green/black @ hood pin switch under hood
trunk release - pink @ BCM
tach - NOT white/blue or black at igniton coil or fuel injector
speed sense - white/green at radio harness
brake wire - pink/blue @ brake pedal switch
parking brake - lt. green/black or purple/red @ parking brake switch
horn trigger - green/black @ horn switch
Old Aug 19, 2007 | 02:34 PM
MyLilBlkG's Avatar
thanks a bunch! you're a real help.
on another note, have you had any experience with compustar, apparently i heard they are one of the harder unit to install.
Old Aug 20, 2007 | 04:05 PM
G-Rated's Avatar
does this apply for 05 also and what is bcm?
Old Aug 20, 2007 | 04:20 PM
KPierson's Avatar
No, those are for the '04. The '05 may or may not be different.
The BCM is the Body Control Module, located in the drivers kick panel.
Old Aug 20, 2007 | 08:16 PM
G-Rated's Avatar
oic thanks well if someone know if there the same as 04-05 feel free to let all of us know
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
master111
Oct 6, 2015 01:36 AM
9tray turbo
Sep 29, 2015 10:22 PM
