Thinking of a small upgrade.
Old Aug 30, 2007 | 05:19 PM
GBoy's Avatar
Hi....thinking of a small upgrade, I have a 03 sedan with the Bose system
A couple of years ago I swapped out the front speakers to Infiniti
components 6000cs. Now I'm thinking to upgrade the speakers
to Infiniti Kappas (higher end). My question is do I go for the 2 ohms
or 4 ohms and since I have a Infiniti 2 channel amp(7520A) sitting
in my basement should this be used in any way, also was thinking of
dynomatting the door and mdf, just not sure what to do to turn it up a notch.
Thanks
GBoy
Old Aug 30, 2007 | 06:39 PM
erdog's Avatar
Thanks
GBoy
I doubt you'll get that much of a performance upgrade with the swap...maybe a little but probably wouldn't be worth the cost.
Turn it up several notches by dropping in a sub and an amp to the sub and components.
Old Aug 30, 2007 | 06:45 PM
GBoy's Avatar
I thought about driving the front components with my 2 channel
Infiniti amp and let the Bose amp do the rest..I'm the only one driving
the car..with no one ever in the back..
Old Aug 31, 2007 | 07:27 AM
GBoy's Avatar
Anyone??
Old Aug 31, 2007 | 08:51 AM
g35rcr's Avatar
get 4 ohm then and get a 2 channel amp that has 150 rms
Old Aug 31, 2007 | 01:05 PM
GBoy's Avatar
I have the 2 channel amp, so just get some better speakers
and dynamat the doors and install the 2 channel amp to run the
front components and let the bose amp run the back doors and sub.
and should be better than my current set up..
Old Aug 31, 2007 | 03:36 PM
g35rcr's Avatar
what are the stats on your amp
Old Aug 31, 2007 | 04:41 PM
GBoy's Avatar
Infinity Reference 7520a
2-Channel Amp SpecificationsAmplifier Type: 2-channel
RMS Power @ 4 Ohms: 97W x 2 @ 14.4V
THD at 4-Ohm RMS Power: <1 %
Bridged RMS Power @ 4 Ohms: 283W x 1 @ 14.4V
Speaker Level Inputs: yes
Preamp Outputs: yes
Built-In Crossovers: HP/LP
Bass Boost: 0 - 12 dB
Frequency Response: 10-69,000 Hz
Signal to Noise Ratio: 83 dB
Fuse Rating: 30 amps
DimQ
Aug 14, 2015 02:04 AM
BlackGee35
Aug 12, 2015 08:41 AM
Herbbie Hablib
Forced Induction
Aug 11, 2015 06:22 PM
helalo
Aug 10, 2015 08:21 AM
TWASkyliner
Aug 1, 2015 11:43 AM
