2003 Sedan Bose speaker sizes
Old Feb 8, 2004 | 01:51 AM
tedtf's Avatar
Can anyone give me the 2003 sedan bose premium sytem speaker sizes? I knoe there are 2 tweets up front, 1 speaker in each of the four doors, two on the back deck and a sub. The system sounds flat needs mid and highs.
2003 Brilliant Silver Sedan 6MT
Old Feb 9, 2004 | 11:57 PM
redright's Avatar
Re: 2003 Sedan Bose speaker sizes
There are only seven speakers. Two tweets, two mids in the front door, two mids in the rear door and one lame sub. I change all of mine to Polk's The 1" tweets do fit in the stock area. you need to take the old twwet out and bend the bracket a bit but they do fit. The front and rear doors are 6.5". I went with DB components in the front and DB coax in the rear. I bought rear door brackets for the front from the dealer. They fit perfectly in the front and the Polk's fit right in. I bought a Fosgate 8" sub and mounted in the rear deck. Needs lots of Dynamat and a baffle from Crutchfield. All ran with a Fosgate 551X. Looks clean and sounds great!
Old Feb 10, 2004 | 09:22 AM
RacerX's Avatar
<hr></blockquote>
Can you elaborate on this part of your install a bit?
How did you get an 8" sub to fit in a 6.5" hole?
Which Sub did you use?
How much power are you driving it with?
Can you be more specific about the baffle; is there a part no you could share?
Is it a free-air sub?
Can you post some pictures?
Most important, how does it sound???
04 G35s 6MT BS Aero Kit/Nav/Prem
Warning: Objects in Mirror Are Losing!
marsman328
Northern California
Aug 11, 2015 07:29 PM
Xanthan Gum
Aug 6, 2015 10:49 AM
realtalk21
Jul 20, 2015 09:07 AM
