Another OEM iPod link install (with pics)
where can i get the kit and which one ....the USA SPEC PA11 NIS one ??? or this one iPod Factory Integration Coupe/Sedan
[999U7-IPOD]
http://www.g35parts.com/9083/osc/pro...roducts_id=521
[999U7-IPOD]
Originally Posted by ShanesG
^look It Take 5 Min To Look And See If You Have The Connection, I Think Some 03-04's Dont Have The Sat Hook Up......if You Dont I Know Theres Another Kit You Can Buy That Hooks Up To The Back Of Your Hu.
your 2006 looks like it has more.....but from my pics will this work? .....i dont have sat but there's still a plug back there
[999U7-IPOD]
[999U7-IPOD]
I did not cut up my seats like others have, something about tearing into my seats just did not sit well with me. So instead I installed it under the middle center console of the rear seats so no cutting was required. I'll take a picture and post it later.
^+1 here is where I ended up placing the ipod integration kit, it fits perfect in that little red square between the seats under the arm rest, and there is about 2 mm space between the kit and that wire that holds the arm rest in place.
<a href="http://imageshack.us"><img src="http://img529.imageshack.us/img529/6705/img3111tq1.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a>
<a href="http://imageshack.us"><img src="http://img134.imageshack.us/img134/4095/img3113jw2.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a>
Originally Posted by mt7rabbit
^I got the factory integration kit from everythingg35.com and installed it in my 05 coupe last night, it works perfect. My trunk looks just like yours I don't have sat nav eigther so you should be okay.
I Ditched the Car PC Project because of this !! was in the middle of the project
but after the iPod Factory Control and the 160 GB iPod Showed up, this is so far the BEST way to listen to MP3`s in a 04 Factory Radio.
Originally Posted by syshs
I went here to buy this kit... but I have a quetsion...
By, satellite radio installed, do they mean just having the satellite radio box in your trunk or actually having satellite radio service???
The "YES" satellite radio option is for vehicles WITH satellite radio installed. If you are pre-wired, but do not have satellite installed and don't plan to install satellite radio, you should select "NO" as you will not need the optional harness.
If your G35 is a 2003 model and it is not pre-wired, then you will need to purchase the pre-wire harness in order to connect the ipod unit, to your factory radio.
