door and rear side speaker panels
Old Sep 23, 2007 | 05:16 PM
daniel-6speed's Avatar
Can anyone tell me how hard is it to remove the door and rear side panels on the G35 coupe to replace the speakers?
I would like to put in new speakers but it seems like its really complicated.
Thanks for your input in advance.
Daniel
Old Sep 23, 2007 | 05:59 PM
shipsaeki's Avatar
for the front door, remove the cover where the handle is (where you would grip if you're closing or opening the door from the inside) with a flat head screw driver. you'll find two 10mm bolts, remove those. then you can see a little cover where the other door handle is (the handle you pull open the door) remove that with a small flat head to reveal another 10mm bolt. Then grip the bottom of the door panel and pull.
rezendvous420
May 31, 2020 01:26 PM
xluke
Jul 30, 2016 01:48 PM
wonderizm
Sep 24, 2015 03:09 AM
will091195
Jul 27, 2015 09:19 PM
emorehs
Jul 17, 2015 09:45 AM
