help with sub install in sedan
Old Oct 6, 2007 | 02:57 AM
fkneh's Avatar
where are the wires in my trunk to hook the LOC's up to so i can run an amp and sub.
This is in a 03 sedan without the BOSE system.
Old Oct 6, 2007 | 09:36 AM
Gilley's Avatar
You need to connect your LOC to the rear speaker wires, which will probably be easier to do before they go into the rear doors. The non-Bose system may have a harness in the trunk, I haven't personally checked, but if it is there, it won't be active.
Old Oct 8, 2007 | 08:17 PM
JoClezyG35's Avatar
pull out the radio and tap off the radio harness, and ur acc wire there anyways.
Old Oct 9, 2007 | 12:10 AM
fkneh's Avatar
damn i was hoping for an easier way since taking the radio out looks a little time consuming.
what is the acc wire?
thanks for your guys help
Old Oct 9, 2007 | 07:45 AM
Gilley's Avatar
Tapping into the Bose system in the trunk isn't any easier.
Acc is accessory.
Old Oct 10, 2007 | 04:54 PM
JoClezyG35's Avatar
YOU COULD just hook up one speaker and tie the loc together, not the greatest but hey.
Old Oct 11, 2007 | 03:47 AM
fkneh's Avatar
so i just hook my loc up to the acc wire
what color is this wire
thanks
Old Oct 11, 2007 | 09:38 AM
Gilley's Avatar
^ That won't work. The acc wire is a 12 volt wire. No audio signal goes through it. You have to tap into the audio wires.
Old Oct 12, 2007 | 12:01 PM
InvincibleG's Avatar
I have the 03.5 sedan w/o premium BOSE, so you have no bose at all? If you are like me then even in the non premium there is an amp in the trunk. Its on the under side of the rear deck. There you can hook up the LOC and the ACC wires.
Old Oct 19, 2007 | 06:25 PM
fkneh's Avatar
which side is the amp on
im confused about this acc wire.
what do i need it for?
thanks for helping me out
jsimonk
Dec 22, 2023 03:49 PM
Jusseth
Sep 13, 2020 12:25 PM
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
Mkhlmnn
V36 Brakes, Suspension, Wheels & Tires
Aug 1, 2015 12:00 PM
joedaddy1
Jul 28, 2015 02:58 PM
