Question on Double Din.
Question on Double Din for 05 Coupe with OEM NAV.
I purchased a double din from Riverside Inifinit, but, when I installed it, it is a little to long. It stuck out on top. Look like I need to sand it down a little.
Did i purchased the wrong one? Is there one for people that have OEM NAV?
I have a 2005 coupe with OEM NAV.
Thanks in advance.
Thanks in advance.
Last edited by tommyz9; Oct 8, 2007 at 01:52 PM. Reason: added pics - Question on Double Din for 05 Coupe with OEM NAV.
The double din do not fit perfectly. It is a little longer in lengh so it over layer the NAV frame. I will try to take some pics later. thanks.
Originally Posted by Gilley
What stuck out on top?
I'm not aware of a different trim piece for the navi equipped cars. The navi equipped cars use a different metal bracket, but you can use your own, which you probably did.
Your issue looks like something just needs to be reinstalled and aligned. There are some screws that hold the cubby hole in place. Try adjusting them.
It was late when I pick up my car. I didn't see how bad it was. I will take it back tomorrow to see if they can reinstall the frame.
