Zune/ipod install
Old Oct 26, 2007 | 09:58 PM
g35 gms's Avatar
Zune/ipod install
Is there a way to install my microsoft zune ipod in my 07 Coupe thru the factory Bose system.There is no aux jack and I do not have Nav.
Old Oct 28, 2007 | 04:39 PM
PotomacG's Avatar
If you don't have SAT radio, the specusa iPod adapter does have L/R aux inputs that you could get a mini adapter for and plug in a Zune.
You will not be able to use steering wheel or radio controls (other than volume).
Old Nov 4, 2007 | 03:45 PM
g35 gms's Avatar
zune install
I cancelled my sat radio so this kit will work yes?
Old Nov 5, 2007 | 04:25 PM
PotomacG's Avatar
The reason it's not compatable with SAT is because it uses the SAT jack on the back of the head unit. If you don't use your SAT, you will have to identify which connector you need to unplug on the back. You could disconnect your SAT cable and just let it dangle back there.
As far as how the Aux Inputs work with the head unit, I would call USA SPEC and find out before plunking down your cash.
G-MAN (CANADA)
Canada
Sep 7, 2015 03:51 PM
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
