Metra 70-7550 vs 7551...which one???
Old Oct 29, 2007 | 10:51 AM
mars35's Avatar
Can anyone provide some input on which one to use...
I have a 2006 sedan- non bose that will be swapped out for an avic d-3
I have read that some of you used 70-7551, however I am thinking the 70-7550 is what I should be using.
Note - Non-bose and I dont have any intention of installing amps...
I think the 70-7551 has the amp (rcas) connections, but many noted this on their install, I am assuming that they were hooking up amps
I am that sure so I would like some help!!!
thanks guys
Mars35
Old Oct 29, 2007 | 11:41 AM
shawnp1178's Avatar
You would use the 70-7550 since you don't have a factory amp. The Avic would power the speakers.
If you had the bose system you would have used the 70-7551 since the bose amp needs a low level signal. hope this helps
Old Oct 29, 2007 | 11:52 AM
mars35's Avatar
shawnp1178
thanks for the confirmation...much appreciated
Nick
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
JoeMac
Sep 28, 2015 12:28 AM
Siciliang35
Sep 18, 2015 11:22 PM
AuAltima3.5
Sep 13, 2015 11:48 AM
Crappyday
Aug 27, 2015 10:26 PM
