Dual Climate Control Button with DD Install
Old Nov 8, 2007 | 12:49 PM
08G37TX's Avatar
I have searched already and can not find a concrete answer. What is the purpose of soldering the old Dual Climate Control button and LED on the JDM AC Controller?
Is it just for the look of having the look of the Dual Button rather than the dummy button?
Or, is it becuse you will regain use of the Dual Climate Control?
Old Nov 8, 2007 | 01:04 PM
JTG35's Avatar
You don't need to solder it if your car is not equipped with Dual air function. I did mine because I want the LED to light up as well as using my dual air. Most of all it looks better than a blank button don't you think?
Old Nov 8, 2007 | 01:05 PM
08G37TX's Avatar
I have Dual Air now and want to keep it. If I resolder it on will I still have use of the Dual Climate?
Old Nov 8, 2007 | 03:00 PM
JTG35's Avatar
Yes, all you have to do is solder the resistor 242 and led to blank spot and it will work.
Old Nov 19, 2007 | 10:05 PM
thinhdle's Avatar
I don't know how did your guys remove this little tiny resistor and solder it to the new circuit board. I took a look at it and gave up.
Anyway, I'm happy with the metra dash kit.
Old Nov 20, 2007 | 07:37 AM
Gilley's Avatar
I used a soldering iron (not a soldering gun - unless yours has a small tip) and some small needle nose pliars.
Old Nov 20, 2007 | 02:46 PM
JTG35's Avatar
^^ lol actually its not that hard.
Old Dec 5, 2007 | 03:50 PM
g35guy86's Avatar
Is there a DIY anywhere? I feel like I've seen one around here somewhere but search isnt helping me.
Old Dec 5, 2007 | 05:02 PM
Gilley's Avatar
There isn't a DIY, but there is a picture showing what needs to be done with the 05-07 AC controller. search for posts bu silvernole.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
WillisFL
Dec 29, 2016 08:56 AM
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
Racova
2nd Gen (V36) Sedan
Aug 8, 2015 10:21 PM
Cacoepy
Aug 3, 2015 01:09 PM
