Quick questions about OEM navi install
Old Nov 19, 2007 | 04:36 PM
KevinHeld's Avatar
I know it's been done and am thinking about doing it myself. I know DD is easier and cheaper but I'm willing to spend more and work harder to maintain a stock look. I just had a few quick questions.
Where does the Navi antenna go? I've been looking at pictures and can't find it. I want to make sure it's not gonna interfere with my XM antenna.
Second: When buying the system, I know the year is important, but is there any difference in system between a coupe and a sedan of the same year?
Thanks
Old Nov 19, 2007 | 05:06 PM
G-Rated's Avatar
take the clock area out should be a place where u can screw it right hand side of the clock...
Old Nov 19, 2007 | 05:20 PM
G-Rated's Avatar
Old Nov 19, 2007 | 06:14 PM
KevinHeld's Avatar
thank you. Any clue about differences between coupe and sedan?
Old Nov 19, 2007 | 06:42 PM
03Sg35's Avatar
I just got my Navi from Ebay and I got a wiring harness for a navi g35c, Im hoping that when the harness comes in I can pull the navi part of the harness and splice into my non navi sedan harness. Both of the harnesess are from 2003 infiniti, Im praying they are similar. I need a GPS antenna anyone have one ?? Or where can I gt one?
Old Nov 19, 2007 | 08:47 PM
G-Rated's Avatar
should be the same i couldnt see why they would make it different beside for the cluster
Old Nov 19, 2007 | 08:49 PM
G-Rated's Avatar
after you split it from the harness it shouldnt matter if it was from a coupe or sedan reason is because the navi itself works on its own rather then depending on the cars ecu...there are a few wires that u need to tap but that shouldnt be hard
Old Nov 19, 2007 | 09:22 PM
03Sg35's Avatar
Well thats good news^^^I was little worried, I will try to take some pictures and maybe some tips after I finish this swap for future people who would like to try this. I found an antenna so looks like I have all needed parts. Any tips G rated??
Old Nov 19, 2007 | 09:25 PM
03Sg35's Avatar
What about the diffrence between the gauge clusters??? I know there is a speed pick up coming from the speedo, anyone know the wire color??
Old Nov 19, 2007 | 11:53 PM
G-Rated's Avatar
theres 3 wires goin to the cluster...black/red......white/red....and grey doesnt matter because i've put those 3wires which is for the fuel info...it goes into the harness in back of the cluster also doesnt work i dont know why i think i might need the cluster w/n = with navi....the speed sensor wire is white green it can be found at the radio harness also im not sure about 03-04 but the 05's have speed sensor in there radio harness good luck with the insall please do a diy for others...
Old Jan 7, 2008 | 02:50 AM
serturbo's Avatar
any update on the install?? how did it go?
chinee
Jun 10, 2024 07:48 PM
EPG35
Aug 16, 2015 04:52 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
