Which one is remote wire for 07 G35 w/ Bose?
Old Dec 6, 2007 | 06:03 PM
B L U E S L A T E's Avatar
Honda Accord
I'm looking at the service manual and figured out the rear sound signal I'm going to tap on for the amp, but it's the remote wire I'm confused...
Can anyone help?
Here's the pic from service manual.
Terminal 23~26 is what I'm going to use, but which one here is the remote?
Is it 20 the Amp on signal?
Old Dec 6, 2007 | 06:05 PM
Honda Accord
Sorry, here's a better pic.
Old Dec 7, 2007 | 07:49 AM
Gilley's Avatar
Are there two amps? Pin 20 is the amp on signal while pin 22 is the woofer amp on signal.
Old Dec 7, 2007 | 12:48 PM
Honda Accord
I only see one amp...?
But again, i'm splicing into speaker wires so 20 should be correct right?
Old Dec 7, 2007 | 01:17 PM
Gilley's Avatar
Use a test light or a volt meter and if pin 20 turns on and off with the radio, that one will work.
Old Dec 7, 2007 | 03:27 PM
Honda Accord
Thanks, I just got done with 4 gauge wire from battery terminal to the trunk. It was first time I'm doing this kinda work so it took me a while for removing the panels and etc, but it's kinda fun, too.
Old Dec 7, 2007 | 07:12 PM
Honda Accord
Ok, I'm done, but unfortunately, NO SOUND from the subs. Amplifier is working fine and the connections to the subs are fine, so I'm thinking it's the line splicings I've done. I should have went to Radio Shack to pick those up instead of using the lower gauge splicers.
One question, is http://cgi.ebay.com/CAR-STEREO-HIGH-LEVEL-TO-RCA-LINE-CONVERTER-12480_W0QQitemZ120194505870QQihZ002QQcategoryZ32808QQssPageNameZWDVWQQrdZ1QQcmdZViewItem gonna work with the car, too?
Old Dec 7, 2007 | 07:34 PM
TroysG's Avatar
did you completely bypass the amp to the subs? if so you might not have enough power going to subs in order to move them.
Old Dec 9, 2007 | 04:29 AM
Honda Accord
Ok, my amp and subs are working fine and I confirmed this by using an iPod to test them.
As I suspected, it's the high to low converter that spliced into the OEM lines. I'm going to try 16, 17, and 22 tomorrow morning. Apparently, 23~26, and 20 isn't working.... even after I re-done the splicing (I've carefully stripped the wires this time to make sure everything was connectly accrodingly).
Can anyone with the AV knowledge take a look at the AV section in the service manual for 07 model G35 sedan to tell me what I'm doing wrong or better give me some advice?
Old Dec 9, 2007 | 09:59 AM
Gilley's Avatar
If you have the Bose system, you don't need an LOC. The signal should already be low level. That's why there is an amp. That's the way it works in the 03-06 G35 sedans with the Bose system.
Old Dec 9, 2007 | 09:53 PM
Honda Accord
Thx, I got it working today. I just gotta relocate the ground wire and put a capacitor. Thanks for your help everyone.
Old Mar 12, 2008 | 01:28 AM
EnviedG35's Avatar
Bump...is this diagram for before or after the amp?
Old Jun 6, 2008 | 06:42 PM
Jstache23's Avatar
Remote
So was it the 20 (amp on signal)?
Im asking because mines wont turn on either.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
NailBomb
Oct 28, 2015 07:53 AM
JustinMKN1
Sep 18, 2015 03:40 PM
AuAltima3.5
Sep 13, 2015 11:48 AM
