wire diagram
Old Dec 16, 2007 | 10:50 AM
deeman08's Avatar
wire diagram
is this the wiring diagram for all g35 with the bose system or just a certain year? will it work for a 2003?
The wires going into the Bose amp are full range. The Bose amp separates the low frequencies and sends them to the 6x9's.
Here are the wire colors.
Factory speaker harness wiring colors
Front Right + Gray/Silver
Front Right - Yellow/Silver
Front Left + Green/Silver
Front Left - Red/Silver
Rear Door Right + Brown/Silver
Rear Door Right - Black/Silver
Rear Door Left + Green/Yellow
Rear Door Left - Black/Yellow
Rear Deck Right + Blue/Red
Rear Deck Right - Blue/White
Rear Deck Left + Blue/Yellow
Rear Deck Left - White/Green
Head unit output colors
The (+) are all on the same side of the connector.
Head Output Front Right + Orange/Blue
Head Output Front Right - White/Blue
Head Output Front Left + White
Head Output Front Left - Orange
Head Output Rear Right + Blue
Head Output Rear Right - Pink
Head Output Rear Left + Teal
Head Output Rear Left - Purple
Remote Wire Light Blue/ Silver
Old Dec 16, 2007 | 01:33 PM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
I guess I don't understand the question and what you are exactly trying to accomplish.
can you please elaborate and provide some background?
doc
Old Dec 16, 2007 | 04:33 PM
Gilley's Avatar
It is my understanding that those are the colors of wires at least for the 03-04. I gathered that information from older posts piece by piece and put it all together.
Old Dec 16, 2007 | 07:06 PM
deeman08's Avatar
i am wanting to instal a line converter in an 03 sadan
Old Dec 16, 2007 | 10:14 PM
hurricanebsball's Avatar
Me too but have been unable to do so because mine dont match up with that diagram. I have an 04 sedan w/ Bose and have looked at the blue wire harness that goes into the Bose amp and nada! Nothing! None of the wires match up! I real close to giving up and just saying F it and buying a Kenwood 7100.
Old Dec 16, 2007 | 11:11 PM
Gilley's Avatar
Those wire colors may not match up to the sedan wire colors. The sedan wire colors are probably listed in the service manual.
The Bose system doesn't need a line level converter because the audio signal is already about 2 volts, which is already on the low side. You just need to cut an RCA cable, strip the ends of the + and - wires, and wire it into the harness. The RCA plugs will then plug into your amp.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
prinny
Nov 22, 2015 11:07 PM
master111
Oct 6, 2015 01:36 AM
9tray turbo
Sep 29, 2015 10:22 PM
the93owner
Sep 28, 2015 10:37 PM
