JL Audio 500/1 amp settings
Old Mar 3, 2004 | 09:08 PM
DiamondG's Avatar
For those of you who own this amp or is knowledgeable in car audio, what are your settings? I know mine needs some tweaking because I only hear certain bass frequencies. Any suggestions on where to set:
Preamp output filter
Infrasonic filter
Bass EQ
Amp Low-Pass filter
Input range
Thanks!
Ken
99 Supercharged Civic Si SOLD
03.5 DG 6MT Coupe w/Aero, Premium, tint, mudguards, MB Quart Q Series, JL Audio 300/4, 500/1, ProWedge
AIM: Ken99Si
Old Mar 4, 2004 | 01:33 AM
al503's Avatar
Re: JL Audio 500/1 amp settings
check out the jl website. They have a pretty comprehensive tutorial on setting the settings.
Old Mar 4, 2004 | 07:12 AM
Ah4ku's Avatar
http://www.infinitecaraudio.com/cgi-...talogno=JL5001
Old Apr 17, 2006 | 04:33 PM
Virge's Avatar
straight to the bank...
BUMP: for anyone willing to share their settings....
Old Apr 17, 2006 | 11:00 PM
khsonic03's Avatar
A good start would be to tell us what kind of sub you have, what kind of box you have (ported or sealed), and what the volume of the box is. You should also check out the JL manual. If you don't have access to a scope, you should use the digital multi-meter gain adjustment as indicated in the manual.
Old Apr 18, 2006 | 12:00 AM
Virge's Avatar
450/4 -> 500/1 -> jl audio 10" 10w6v2 in a 4080 box
Currently I have the lpf @ ~55hz and the Infrasonic filter at about 30. Thats it.
The problem for me is that it sorta cut out most of the bass. If I turn the infrasonic off then there is way too much bass... :/
Old Apr 18, 2006 | 12:09 AM
colds14's Avatar
Turn the infrasonic off when in a sealed. If its to loud after that turn the gain down. Going by the manual is a good thing but is not needed. The cross over is fine at that setting, if you want more upper end bass turn it up to 65 if you want less boomyness bring it down to 45 or so.
Old Apr 18, 2006 | 07:21 AM
khsonic03's Avatar
That's some pretty poor advice. Gain is NOT volume adjustment. You are matching the input voltage from your HU, and preventing clipping which can cause severe damage to your speakers.
Old Apr 18, 2006 | 07:34 AM
Virge's Avatar
I have no bass boost at all (switch is off)...doesnt seem like I need it. I was thinking that the Infrasonic was a good idea since the 500/1 is way more power than is needed to power the 10w6v2...
also I have the input voltage set to low...and my lpf mode setting is at 12db increments instead of 24db...
Old Apr 18, 2006 | 09:21 AM
colds14's Avatar
Yes the gain is not a volume adjustment, now depending on the situation though, going by the level matching is not always the best thing. A properly tuned "ear" can match a sub to an amp very well. The only time that I set up amps with the "proper method" is when I'm tunning an SQ car. Everybody hears differently and there for the same method does not apply to everyone. Never make adjustments that lead you to clipping of the amp and distortion.
Old Apr 18, 2006 | 10:27 AM
khsonic03's Avatar
Well, he's obviously asking us because he does not have a finely tuned ear, and probably doesn't know exactly what to do. So I don't feel that would be the best advice for his situation. He's not a tuner, so he should probably use the recommended method.
Old Apr 18, 2006 | 10:55 AM
Virge's Avatar
yea definately not a "tuner" but I have a feel for what I would like it to sound like... I just dont have the experience fiddling with amps to get it how I want. The guy who installed the system tuned it really weird, with the front components filter set at ~120 hz, rear 6x9's at about 100 or so, and the sub at 85. The bass was so much i couldn't even hear the tweets half the time... :/
Old Apr 18, 2006 | 01:03 PM
khsonic03's Avatar
Wow, this whole time I thought this was for the first guy (Diamond). I didn't realize his post was from 2004!! lol
Old Apr 18, 2006 | 01:10 PM
Virge's Avatar
lol well i hate bringing back old threads but the topic was sorta left unanswered and I had a relevant question
hdmark
Apr 29, 2019 04:31 PM
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
Frostbite91
Audio/Video/Electronics
Dec 27, 2016 11:02 PM
broke_as_ajoke
Nov 6, 2015 11:49 PM
Cacoepy
Aug 3, 2015 01:09 PM
