Need some Info/Advice on speakers
Old Dec 30, 2007 | 11:38 PM
infidsg35's Avatar
I have a 03 Coupe with Bose system..
I will be replacing everything HU/Speakers/Wires and adding Amps/Subs
I will be getting Infinity Perfects for the Front doors.
My problem is with the rear...
Should I replace the rear sides and just remove the rear deck?
Should I replace the rear panel and just remove the rear sides?
Should I just replace all of them? (Not sure how to do so tho)
Ill be using the Kicker ZX650.4
Thanx in advance!!!
Old Dec 31, 2007 | 01:04 AM
04G35NYC's Avatar
IF you want more bass into the interior take all the speakers out. Are you just getting components for the front... i would go components all around i have done that in my last car that was coupe it was perfect 2 sets of components all around with nice HU and a sub doesn't get better than that.
Old Dec 31, 2007 | 01:16 AM
infidsg35's Avatar
Thats what im thinking. I dont think I want 3 set of speakers. I am def doing the perfects up front but not sure what to do about rear... I def want to have atleast 2 set just not sure if I should go sides or rear...
Maybe just put perfects in front ans rear sides and call it a day?
And yes I will be putting 1 10" L7 in trunk
Old Dec 31, 2007 | 08:29 AM
Gilley's Avatar
I installed components up front, coaxes in the rear sides (they're only for a little rear fill) and removed the 6x9's to allow the bass to come in. I like the results.
Other people replace the 6x9's with new ones. But there is no need to replace all 3 sets of speakers. The Bose 6x9's are there only for bass.
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
MrIP35
Oct 25, 2015 11:13 PM
1Typhoon
Sep 25, 2015 08:45 PM
JustinMKN1
Sep 18, 2015 03:40 PM
Mikesta
Sep 10, 2015 05:14 PM
