double din setup
Old May 9, 2008 | 11:43 AM
ShanesG's Avatar
^tell me about it
Old May 9, 2008 | 03:01 PM
bombaclothras's Avatar
Check this thread,I got my work done at Maximum Auto Sound in Garwood, NJ. I used the Metra dash kit for G35 If you have Navi, do not use this kit is not made for a navi. They had to somehow alter the dash kit for my navi to fit. https://g35driver.com/forums/picture-share/213310-ob-coupe-spring-misc-pioneer-z1-install-56k-beware.html
Old May 9, 2008 | 04:52 PM
nfo184's Avatar
how much did it cost to get ur hu installed?
Old May 12, 2008 | 05:02 AM
G35ANSTA's Avatar
Originally Posted by S33kio
There ya go... I posted because I know how long it took me to search for a different pics of Double Din setups lol.
I just installed the Z3 with the OEM DD replacement as well, but don't you hate the fact that the color of the vent edges dont quite match the color tone of our tan 03-04 G35? I didnt realize the color was diffrent when i prchased the DD from Grubbs. Are all the OEM DD the same color?
By the way I just noticed that u have a small switch on the left side of ur HU, is that to bypass the Pioneer's security feature for playing video?
Old May 14, 2008 | 11:21 PM
nfo184's Avatar
how do u get the clock trim piece off???? lol i want to install my double din and cant even get it to come out
someone help.....or pm me or something
Old May 15, 2008 | 12:38 AM
Deezflip's Avatar
You wedge your fingers at the top left corner first until you get enough grip,
....then you pull like h3ll!, well maybe not like h3ll, but with a good amount of force. It may seem like it'll break but you'll have to trust that it'll come loose.
Old May 15, 2008 | 05:18 AM
Dan_K's Avatar
Originally Posted by JY35
dd cost about 90 and the ac controller is really expensive like 190 or something like that but there are package deals.
Oh, and dual climate controller add about another 50
Don't you also have to buy the bracket?
Why do you need to pull the clock trim off to install a double din?
Old May 15, 2008 | 06:52 AM
white_dc5's Avatar
Theres a screw that you need to take off and can access by taking off the clock trim.
Old May 15, 2008 | 06:07 PM
nfo184's Avatar
I finally got the clock trim piece out......(the whole pinching thing that everyone does i guess didnt work on my car) ....... The metal clips were like bent open so it wouldn't come out....but after using 2 putty knife scrappers wrapped in cloth i went it from each side and pried it out
but now after removing all the bolts (1 by clock and 2 down by shifter at the bottom of the clock)
i have a 2004 with bose...have all the bolts removed but cant seem to get access to the wiring harnesses and get it to come loose
should i remove the lower panel and side panels also ??? where the 12v power sources are??? and the glove box???
I dont know what else its stuck on.....i got the bolt on by the clock and the 2 at the bottom.....it seems to wiggle but its still stuck in there
Old May 15, 2008 | 10:02 PM
Gilley's Avatar
Did you remove the bottom panels on either side of the center console - the glove box and panel under the steering wheel? The DIY shows you what to do.
Old May 15, 2008 | 10:15 PM
Dan_K's Avatar
Link?
Old May 15, 2008 | 11:12 PM
Deezflip's Avatar
my favorite DIY...
just make sure you press on the correct "next" button on the bottom page, it always confused me as one button will bring you to a different diy.
http://www.autotalk.com/how-to/infin...o-install.html
Old May 17, 2008 | 03:02 PM
nfo184's Avatar
heres the guide to remove a 03-06 g35 double din
http://www.autotalk.com/content/view/214/2/
and heres another site also
http://g35ipod.com/installHW.php?skin=1
Marlin84
Apr 1, 2020 12:52 PM
DRG35R
Jan 31, 2016 07:14 AM
BfloG35
Audio/Video/Electronics
Oct 16, 2015 05:22 PM
AL8782
Oct 3, 2015 10:26 AM
