A/C Cooling Power??
Old Oct 10, 2002 | 12:52 AM
Mr_G35's Avatar
A/C Cooling Power??
Has anyone had a slight problem w/ the A/C's cooling power...
at speeds 1-4 it doesn't seem to be blowing as much cool air as it should...only at speed 5 it blows that massive amount of air...Does this have anything to do w/ the A/C problem that people are having?
Old Oct 10, 2002 | 01:00 AM
2003blueG35's Avatar
Re: A/C Cooling Power??
No ... the AC problem is a loud noise that happens above 3000 rpm. If you do not have passengers you can try closing other vents. I have not noticed an issue with the amount of cold air blowing at any speeds.
Old Oct 10, 2002 | 11:15 AM
Poindexter54's Avatar
Hold on!
You mean not enough cold air? Mine works great. And I have a black car in texas. (I know, crazy)
I have mine set at 80 (auto) most of the time unless the humidity is way up and the temp is 76 or so, then i set it down around 72.
The blower works great too. Thats why im aprehensive about getting the new compressor. The old one is load but it works!
G35Rican
Jul 31, 2024 01:37 AM
JLee301
Sep 25, 2015 08:46 PM
reaper76
Sep 20, 2015 11:59 AM
mattdg35
Sep 14, 2015 11:28 AM
