Intellikey and aftermarket alarm
Old Feb 19, 2008 | 11:44 AM
CHUPA Hunter G's Avatar
Besides the Viper 330V. What are some other choices so that I'm not carrying two remotes? Also want more then just a shock sensor... motion sensor as well.
Old Feb 19, 2008 | 12:40 PM
theimmortal's Avatar
Found some interesting info here:
http://www.tintdude.com/forum/index....7&#entry378967
And a system that looks pretty good here (mentioned in above link):
http://visionsecurity.jp/en/systems/1440R.html
Old Feb 20, 2008 | 04:40 PM
Saw that doing a search. Any idea what people are paying for those shipped from Japan with a shock sensor?
Old Feb 29, 2008 | 09:23 PM
Stinkfist480's Avatar
I just added the Hornet (made by DEI, as well). Works great, the only "issue" I have is that I can't unlock BOTH doors using the door handle (fob works fine). Could just be a programming issue. In addition to the standard shock sensors, starter kill, and siren, I also added a backup battery, a tilt sensor, and a siren inside the car. All can be controlled without the need for a second fob.
http://www.hornetcarsecurity.com/Pro...?ProductID=805
Hope that helps.
Old Feb 29, 2008 | 09:49 PM
ttrank's Avatar
Grocery getter
What the shop I know does is uses a non-prox key with a 555U to start the car with a standard remote start alarm.
jeffbdye
Jun 1, 2018 03:51 PM
g.spot
May 9, 2016 10:54 PM
Fox843
Nov 7, 2015 05:43 PM
Learned Hand
Oct 1, 2015 09:02 AM
