LOC Question
Old Mar 21, 2004 | 02:36 PM
GoSooners's Avatar
LOC Question
Hey guys, I'm purchasing wiring for my audio setup and was wondering what's the best LOC? Also, with a 2 amp setup, should I get a 4 channel LOC and run 2 separate RCAs or, would a 2 channel LOC work if I go out of the preamps from 1 amp to the other? Which option gives a better/cleaner signal? Amps are JL Audio 500/1 and 300/2
Black on Black 5AT Coupe, Navi
Axis Milanos 19x8.5 F 19x9.5 R
Toyo T1S 255/35 F 275/35 R
HKS Legamax Exhaust
350Z Duct
Stillen Hi Flow
7 Wire Hypergrounding Kit
Old Mar 21, 2004 | 06:42 PM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
Re: LOC Question
I have 2 amp setup + Infinity Bassklink powered sub, my pro car audio install crew went with 2 channel VEN4's. If they do it right, there should be clean signals and no alternator whine whether the LOC is a 4 or 2-channel.
Others may have different setups with differnt results.
Old Mar 21, 2004 | 06:49 PM
RadYOacTVe's Avatar
Re: LOC Question
I went to a car audio shop yesterday to get a quote on an install of speakers and my JL 300/4 and 250/1 and they recommend the Ven4 as well. I asked if using the line in inputs of the JL amps would be sufficient and he said that you will get no noise using the Ven4 which is what I will go with. Nothing worse than hearing alternator whine.
Old Mar 22, 2004 | 05:15 AM
DHCrocks's Avatar
Re: LOC Question
from what I hear soundgate is one of the best out there, pricy though. I've used stinger LOCs in the past and have had no problems with them and they did not intoduce any noise.
Old Mar 22, 2004 | 02:05 PM
docron1's Avatar
Re: LOC Question
What also helps eliminate alternator whine and interfernce noise are the type and quality of the RCAs you use. I used StreetWires ZeroNoise 3 RCAs from the back of my aftermarket deck to the amps in the trunk running it down the driver side (vs. the amp power cable from the distributor block down the passenger side).
Sure the ZN 3's are a bit more expensive than RadioShack RCAs but now I have exactly what they're meant for,
z e r o - n o i s e!
Hope this helps.
migurus
Sep 5, 2015 09:39 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
UT G35
Sep 3, 2015 03:58 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
