Recommend me a 10" sub
Old Feb 24, 2008 | 11:22 PM
BALLINassG35's Avatar
I currently have a 10 kicker cvr is a ZENclosure sealed box in my coupe. Im pushin 250watts rms from a RF punch amp. The Bass is loud, but its not clean! Theres a slight delay between the music and bass, and it sucks. Do you guys think its my sub that sucks, or the amp?
Old Feb 24, 2008 | 11:42 PM
06g35meister's Avatar
I love my alpine type R sub, its perfect clarity and perfect loudness (500/1500W)
before you go buying a sub, i would check what air volume and port youre sub needs, cause youre setup will SUCK if youre off by even 1-2 ft^3. PM me if you need more info.
Old Feb 25, 2008 | 12:14 AM
sfgr415's Avatar
If you are pushing about 250 RMS, a JL Audio 10W3v3 would work out well.
Old Feb 25, 2008 | 12:26 AM
topgun_g35's Avatar
Rockford Fosgate Amp? Keep it in the family. Go with the Rockford Fosgate P3 10. It's dual voice coil, so depending on what model amp you have you would get either a dual 2 ohm or dual 4 ohm voice coil. P3's have great power handling, excursion and sound really good in a sealed or ported box.
http://www.rockfordfosgate.com/home/
Old Feb 25, 2008 | 12:35 AM
sfgr415's Avatar
I would not recommend a P3 because the amp is only putting out 250 RMS, much less than what the P3 wants. A P2 would be more ideal.
Also, I would never recommend running a RF Punch series amplifier at 2 ohms. They have not proven to be 2 ohm stable. The Power series, however, are.
Old Feb 26, 2008 | 12:11 AM
swolg35's Avatar
I'm going with an Image Dynamics ID series sub.
Old Feb 26, 2008 | 10:29 AM
EnviedG35's Avatar
Image dynamics IDQv3. Doesnt need much power to sound great, but will take more power if you ever decide to upgrade your amp. Not to mention they are one of the mostl tonal and accurate speakers i have ever heard, and can get pretty loud,, for the money. IM putting two idqv3 12's in mine with 1200 watts for them.
Old Feb 26, 2008 | 01:46 PM
swolg35's Avatar
Yeah...the reason I went with the Image is b/c it needs very little power to sound good! You can check them out at image dynamics website:
http://www.imagedynamicsusa.com/prod...id=id&type=sub
I believe retail on the ID10V3 is ~$150 and it will work well with your 250RMS considering the sub calls for an RMS of (50W - 400W)
Old Feb 26, 2008 | 01:58 PM
redlude97's Avatar
elemental designs 11kv.2, perfect amount of power for it
Old Feb 26, 2008 | 11:22 PM
Will-i-am's Avatar
I hope you guys are still considering the fact that he is using zenclosures box
Old Feb 27, 2008 | 12:46 AM
EnviedG35's Avatar
Even better for an idq. The 10" only has a 5" mounting depth and requires as little as .5 cu ft.
Old Feb 27, 2008 | 02:14 PM
redlude97's Avatar
or an ED
Old Feb 27, 2008 | 04:21 PM
MICKSKILLZ's Avatar
second
I second the IDQ 10"... that sub is a great choice if you want clean bass... I've used Image dynamics numerous times and have never been more pleased as far as price/performance... that sub should work well with the zenclosure, or else i would use a jl audio w3
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
f22raptor
Mar 18, 2016 08:50 AM
dseet
Oct 11, 2015 12:40 AM
RWDguy4238
Sep 30, 2015 12:13 AM
Detailed Image
Sep 28, 2015 07:04 AM
