IGN wire
Old Mar 22, 2004 | 08:11 PM
g35pimp's Avatar
IGN wire
I'm trying to wire something to the IGN fuse so that it will trigger my device to come on when the car is started. Does anyone know how to wire to the IGN fuse. I looked at the fuse box next to the battery and the IGN fuse is one that I haven't seen before or worked with. So anyone have any instructions on how to do this? Pics would be helpful.
-Noa
Old Mar 22, 2004 | 08:58 PM
Meatshackle's Avatar
Deep Sea Moderator
Re: IGN wire
Any reason you can't tap into the cig lighter or 12v on the passenger side?
Russ
Black 6MT Coupe
Jax, FL
PS2 and Headrest Monitors Thread
Old Mar 23, 2004 | 12:19 AM
tig488's Avatar
Re: IGN wire
if you look in the fuse panel beside the drivers feet, on the bottom row of empty fuse slots, one of those is 12V ign, i think its one almost directly in the middle, check those with a voltmeter.
BS/Graph 6MT Cp
19" GunM TE37 275/30 MPSports
kg/mm,cambers,cuscosways,injen int/exh,Alpine/JL/Stinger,topsecret
Vortech
Old Mar 23, 2004 | 01:56 PM
SLVRG35's Avatar
Re: IGN wire
Remove the 1 screw holding the knee bolster and tap directly into the ignition wire (black w/red). Try to avoid going directly to a fuse used by another device because it could cause it to blow when too much of a load is applied to it.
Old Mar 23, 2004 | 03:57 PM
tig488's Avatar
Re: IGN wire
that also is another option, although if you go to the fuse panel like i mentioned there is no fuse there, it is an empty slot so you can actually tap there and put a fuse in it. i didnt know SLVRG35s method.
BS/Graph 6MT Cp
Vortech
Old Mar 24, 2004 | 07:43 PM
KPierson's Avatar
Re: IGN wire
This method does work really well, but I would suggest you use an inline fuse... if you accidently ground this out you will blow a 10amp fuse in the engine compartment and you car will not start. Also, as I just noticed, according to the service manual the IGN in the ignition harness is only 10 amps!!!! You might want to use the IGN signal to turn on a relay connected to the main 12volt feed in the ignition harness (white/red I believe, 60A). I'm not sure what all is on the IGN circuit already, but I would imagine it's loaded up quite a bit, not leaving much room for additional electrical components. I did do a test the other day to see how much current that IGN wire pulls with the ignition on but the car not running and that was right around 3amps, with the a/c & heater off. (And yes, that is a hint that I am already working on remote sunroof control.....)
www.kptechnologies.net
Kevin
04 Diamond Graphite Coupe - FULLY loaded
Windows up with OEM Remote
Old Mar 24, 2004 | 07:51 PM
SLVRG35's Avatar
Re: IGN wire
The ignition wires are a great place for getting sources of constant/switched power. Just like if you install an alarm or remote start.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
prinny
Nov 22, 2015 11:07 PM
BfloG35
Oct 16, 2015 05:22 PM
9tray turbo
Sep 29, 2015 10:22 PM
the93owner
Sep 28, 2015 10:37 PM
