Will CDT CL-61 fit in G35C door?
Old Mar 26, 2004 | 09:55 PM
jerryg's Avatar
I've used Search and haven't found a concrete answer. I did find a similar thread on the Sedan.
Does anyone know for sure if the CDT CL-61 speaker will fit in the doors of the G35C without any major issues? Will the tweeters fit behind the stock grilles ok?
I know the Infinity Kappa tweeter fits without modification and the Polks fit with some work. The mid-bass might require some trimming of the baffle.
But, the mounting depth of the CL-61 mid-bass looks about 3/4" deeper.
Old Apr 13, 2004 | 11:35 AM
rcanedo's Avatar
Re: Will CDT CL-61 fit in G35C door?
I will know tomorrow if they fit. I get mine installed then. I'll let you know, if there is any custom fitting needed.
See what I'm installing in it here: http://www.cardomain.com/id/rickneuropa
Old Apr 15, 2004 | 10:26 AM
rcanedo's Avatar
Yes, they do!!!!! However, a spacer was used to give more depth. No problems with the door fitting over the speaker either.
Old Apr 15, 2004 | 10:26 PM
Nismoboy's Avatar
rcanedo: how thick of a spacer was needed to make the cl-61's fit? thanks.
John H.
2003 Infiniti G35 Coupe 5AT-Ivory Pearl-Premium Pkg-Performance Pkg.
Old Apr 15, 2004 | 11:37 PM
jerryg's Avatar
Did you fabricate a spacer or purchase one?
Where did you mount the x-overs?
Old Apr 16, 2004 | 04:49 PM
rcanedo's Avatar
The spacers are GM model spacers. The crossovers are mounted right behind the arm rest area.
So far, I have the speakers only hooked up to the bose amp, and they sound a lot better than the Bose did on the high end! It took away from the bose 6x9 bass though, and it's almost non existant now. Once I get my sub and amp installed to power the CDT's, this will be a whole different ballgame, and will blow that Bose system out the door!
Machine Head
Sep 4, 2015 07:22 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
jbmw002
Sep 3, 2015 08:42 PM
kevintandmd
Sep 3, 2015 06:41 PM
erich2780
Sep 3, 2015 03:23 PM
