Mounting Pioneer XM/NavTraffic Tuner GEX-P10XMT
Old Mar 21, 2008 | 11:01 PM
G35 Mass's Avatar
I just ordered the GEX-P10XMT from ebay. Where did everyone mount the tuner? Under the dash or in the trunk?
If you mounted it in the trunk, did you have to buy the extension serial cable? The stock cable is only 8 feet long. Is that long enough to run it from the trunk to the back of the radio in a sedan? Doesn't seem like it would be.
The extension cable is 20 feet long, but is $50 (part CD-600DC).
Old Mar 21, 2008 | 11:13 PM
Boston's Avatar
Ordered mine as well and it's going in the dash. Antenna is going in the cubby behind the clock.
Old Mar 22, 2008 | 12:11 AM
sfgr415's Avatar
Cubby behind the clock? Are you talking about the normal cubby? I dont really want to mount my GPS antenna on the dash and am looking for alternative locations.
Old Mar 22, 2008 | 12:23 AM
Boston's Avatar
No, not directly on the dash. When you remove the clock fascia, you have the clock/temp display and behind that, there are openings or cubby's.
Old Mar 22, 2008 | 12:24 AM
G35 Mass's Avatar
If you remove the clock, there is a place that you can mount the antenna. It's under the dash, but gets proper GPS satellite reception through the plastic/grille area. It's where the stock GPS antenna would go as well.
Regarding the location of the XM antenna: I already have one located on my roof, near the driver's side "C" pillar. I'm not sure if it's because I'm so far East, or whatever, but unless the antenna is on the roof, I loose reception a lot. It's different with GPS because there are multiple satellite locations, so inside the car is ok, but since there is just one XM satellite, there is less room for a blocked signal.
Old Mar 23, 2008 | 12:50 PM
sfgr415's Avatar
thanks... i will take a look when i take everything apart.
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
BfloG35
Oct 16, 2015 05:22 PM
Claudiu
Sep 26, 2015 01:04 PM
