Replacing front speakers.. leave factory speaker grill off??
Old Apr 1, 2008 | 09:47 PM
Red_G35's Avatar
Lightbulb Replacing front speakers.. leave factory speaker grill off??
Hello!
Quick question, want to upgrade my front speakers to something like this..
I want to show off the speaker's looks (the right one). Can I leave the
factory speaker grill off or will it leave an unsightly gap? Any potential
problems? Front speakers are 6-3/4", will installing 6.5" cause any problems?
Thanks for the quick advice... replaced my bose with a kenwood DNX7100
Old Apr 1, 2008 | 10:05 PM
Boston's Avatar
Keep your door panels as they are. Your going to need a spacer for the fronts. I just did an install and used a 1" Metra plastic spacer. I trimmed the door panel to get an almost flush fit.
Old Apr 1, 2008 | 10:07 PM
ernie18's Avatar
one would wonder (me) how you got the panels off
Old Apr 1, 2008 | 10:13 PM
G35Ian's Avatar
I say leave it alone I think that will look awful, but that is my opinion you do what you gotta do
Old Apr 1, 2008 | 10:19 PM
Red_G35's Avatar
Hmm... well anyone have pics? I dont want to do it if it looks like ****.
Thanks for the info all!
Easein2itG, will most all shops have these spacers in stock? Is this somewhat of a custom job?
Old Apr 1, 2008 | 10:32 PM
Boston's Avatar
I'm sure there is a DIY on the door panel removal that will illustrate it but you have three screws to remove and the rest are normal door retainers.
1. remove the square plastic cover located by the door handle lever and remove the screw underneath.
2. Gently pry off the plastic cap cover on your door handle and remove the two screws.
3. pull on the perimeter of the door panel to pop the retainers.
4. once the panel loose, pull up on it to free it from the door frame.
5. disconnect the wiring harness to the windows
6. disconnect the cables attached to the door handle lever.
here's a pic of a Kappa speaker with a 1" spacer
Attached Thumbnails Replacing front speakers.. leave factory speaker grill off??-dsc01625.jpg   Replacing front speakers.. leave factory speaker grill off??-dsc01627.jpg   Replacing front speakers.. leave factory speaker grill off??-dsc01629.jpg
Old Apr 1, 2008 | 10:33 PM
Boston's Avatar
Spacers are common and all shops should have them.
Old Apr 1, 2008 | 10:36 PM
Red_G35's Avatar
Looks nice to me, are those 6-1/2"? Do you have a pic with the poor panel on?
Thanks.
Also, I want to make sure I get better speakers than stock, what kind of specs should they meet/exceed?
Thanks for your info/pics, greatly appreciated!
Old Apr 1, 2008 | 10:43 PM
Boston's Avatar
The speakers in the pic are Infinity Kappa Perfects 6.1 and they are a 6.5" component speaker. They are a 4 ohm speaker but you can get the regular Kappa speaker in 2 ohm. Almost anything you get will be better than what is in there but you should consider an amp.
Old Apr 1, 2008 | 10:44 PM
Boston's Avatar
with the door panel, mine looks exactly like yours.
Old Apr 2, 2008 | 07:44 AM
Gilley's Avatar
OP, you state that you replaced the Bose with the DDX7100, but are you still using the Bose amp with it? If so, you need 2 ohm speakers.
I don't recall if the stock grille separates from the door panel. You can pull the panel off and look. Unless you're going for a custom interior or a show car, you might want to leave the stock grille on.
Old Apr 2, 2008 | 11:25 AM
Boston's Avatar
Sean, I think you're right and I looked at that when I had the panels off. The OEM grille is molded into the door panel so it would have to be cut out. Much better to leave as is.
Old Apr 2, 2008 | 12:11 PM
Red_G35's Avatar
All questions answered. Thanks guys!
Hasanbaloch
Feb 29, 2024 08:45 PM
rezendvous420
May 31, 2020 01:26 PM
vstypicals
Jul 20, 2015 10:55 PM
realtalk21
Jul 20, 2015 09:07 AM
