Engine noise on 300/4 version 1
Old Apr 14, 2008 | 10:10 PM
CLiX`G35's Avatar
I recently did my system:
front: Boston Pro60 components
Rear: Boston Pro60 axis setup
4080 w/ 10w6
jl 300/4 version 1
JL 500/1 version 2
3sixty.2 DSP
I have engine noise coming from the 300/4 amp and i don't know what is going on. each amp is individually grounded using 4 gauge wire. I grounded right inside the trunk on the small piece right behind the spare.
Is this a bad ground location or do i need the big 3?
deos my 300/4 support differential balanced inputs ?
Old Apr 15, 2008 | 05:51 PM
nebbie81's Avatar
What I would do first is see if your amps are grounded to bare metal. Then, are your rca wires running separate from the power wire? Have you tried bypassing the 3sixty.2 and just running the rca's straight to your 300.4 and see if the problem lies within the signal processor. Check and make sure the wires weren't crimped or broken anywhere.
Old Apr 16, 2008 | 04:15 AM
PoorG35's Avatar
Is your ground wire longer than 18inches?
Old Apr 16, 2008 | 05:52 AM
Meatshackle's Avatar
Deep Sea Moderator
+1 to both replies. Grounds need to be short and same or better gauge as power. Verify that your RCAs aren't near your power wires.
You should also upgrade the big 3.
Old Apr 16, 2008 | 09:39 AM
CLiX`G35's Avatar
i have a 2 gauge going in to a distro block then 4 gauge in the amp and 4 guage ground. the ground might be more then 18in ill check that and i definatly have the RCAs near... ill post pics of what that area looks like.
Thanks !!!
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
Cskeet
Drivetrain
Dec 3, 2015 09:18 PM
joedaddy1
Jul 28, 2015 02:58 PM
rping
Jul 26, 2015 09:53 PM
