SWI Research project SWI-JACK SWI-ALP IVA-W200
Old Apr 23, 2008 | 07:17 PM
hilock's Avatar
I to have the Alpine IVA-W200 and have done lots of research on this.
I had problems with inconsistent response and operating by itself.
Now mine works perfect and her is why. After you hook up power to the box there are only TWO wires used from the car's harness that are connected to the SWI. Of course you have to ground a third wire from the car's harness as well leaving one wire not used (white).
Here's where it gets tricky, out of the 4 wires coming from the G's steering wheel harness you'll have used 3 of the 4 (1 - grounded 1 - w/50 ohm 1- w/150 ohm) The directions tell you to connect the remaining WHITE WIRE. Just so happens the only wire on the Infiniti's harness you have not used is white and this may fool you into thinking it needs to be hooked up. I made the mistake of hooking this one up. DO NOT HOOK UP THE WHITE WIRE ON THE G's harness. If you get the instructions from the website you'll see they are referring to white wire on the SWI-Jack box....Not your car.
So that is the basics and should allow you to get it working pretty well. Now for the rest of the story and additional research I found out while solving this problem.
1. Originally I had the SWI-ALP (predecessor to the SWI-JACK). According to PAC it does not accept the same range of values the SWI-Jack does. So this is why I switched and then discovered the wiring problem.
2. Get yourself a multi meter. Ohm resistors (including the ones they give you) are typically only accurate within 5% so buy a pack of ten and use the resistors that are as close as possible to specified values. (I have seen the resistors fluctuate as much as 5 ohms on the 150 ohm resistors.
3. Ground to the frame as close as possible. For me it was behind the shifter bolts go into the frame that hold a bracket for the E Brake Cable. It’s VERY SENSATIVE TO GROUNDING AND I CAN'T STRESS THAT ENOUGH.
4. Finally PAC recommends soldering the connections to the car harness. The do not recommend using "tap Ins" or other easy connectors
I took me a year and a half and two versions of the steering wheel interface adapter. But to your benefit I did a lot of research that will give you the optical installation. I hope it will help you out and would love to hear back from you if it did!!
Now I'm ready for the IVA-505 But then again who knows what will come out in 2009!
Old Apr 24, 2008 | 09:40 AM
urbanlife's Avatar
Thanks, this information came in real handy this past weekend when I installed my W505. This took me the longest to figure out but I found this post and it worked like a charm. I almost gave up but now I'm up and running with the best of then, lol.
Marlin84
Apr 1, 2020 12:52 PM
jeffbdye
Jun 1, 2018 03:51 PM
TurTLe*
Sep 29, 2015 01:43 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
Albanian122
NorthEast
Sep 28, 2015 03:03 PM
