INSTALLED All new Kenwood DNX8120 *PIX*
Thanks for the replys guys, sorry been really busy.
I will post up pictures of the ipod in action..I dont have the HD radio tuner so I am still on the stock antena...The bluetooth comes with the kit. It the new parrot bluetooth so it work AMAZING.
Originally Posted by SIR NUPE A LOT
My 06 has the factory BT installed, how will BT equiped after market HU's affect it?
I think it is like if you have the stock nav, you loose the stock nav voice. The BT HU will prob be your default BT with the new HU. Hope that makes sense.
Originally Posted by Dan_K
Did you need to buy the bracket to install the headunit or did you use to stock bracket?
Also, did you use any wire harnesses for the bose amp?
I used my stock bracket and it worked just fine, all you have to do it drill some screws into it. I heard that you only need to buy a bracket if you have a sedan..<<< Don't ask me why lol, no idea.
Did you manage to fit the trim piece around the frame of the double din? The finisher has too little space for mine to fit. Mines an '04 though.
Originally Posted by OBG3506
Hey, reading the manual, this thing can send txt messages! Man i want one bad!
Hegone, where did you put your gps antennae? its say put on your dash, not cool!
I actually got it hidden UNDER the dash closer to the right corner of the windsheild.
I didn't want it shown.
[QUOTE=Dan_K]Did you manage to fit the trim piece around the frame of the double din? The finisher has too little space for mine to fit. Mines an '04 though.[/QUOTE
I have that same issue, not enough space for the trim, i hate that look, it appears unfinished to me... any suggestions on how to get it to work or maybe an aftermarket trim???????
Hey I installed the dnx8120 too and my ipod worked for a day i took it out of the car plugged it into my computer and the next morning i went to plug the ipod into the adapter and the radio doesn't connect or charge the ipod but if i choose a song using the ipod it does play... to make it wierder if i plug in my older ipod it charges but i still cant control the ipod from the hu. Any ideas???
P.s. I also tried restoring th ipod but since i bought it a week ago theres not much to go back to.
