tvandnav2go install problem with rear view input
Old May 17, 2008 | 03:00 AM
the04coupe's Avatar
I just installed a tvandnav2go unit as well as a pac aai nis2,ps2slim,rear view camera and ipod . The problem im having is that the camera wont display picture . When the car is in reverse the display does switch but just blank screen . The ps2 and ipod work fine . Nows heres the weird thing . if i take the video plug out of input 1(ps2) and put it in input 2(rear view input)on the nav2go box i dont get picture either . Now i tried puttin the camera on input 1 that i know works and again no picture . put the ps2 in input 1 again ,,,pictures there . The camera is getting switch 12v and ground . Is it the camera or the nav box ???
Old May 17, 2008 | 04:41 AM
Meatshackle's Avatar
Deep Sea Moderator
Try putting the ps2 on input2 and putting your car in reverse. The box should only switch to input 2 when in reverse right?
Old May 17, 2008 | 11:42 PM
the04coupe's Avatar
still does not work that way
Old May 18, 2008 | 05:30 AM
Deep Sea Moderator
Can you hook up your camera to a tv or monitor? Use the same switched 12v and run the rca to a tv/monitor.
That will determine if your camera is working properly. If it is, then you know it's the tvnav box.
Old May 18, 2008 | 11:45 PM
the04coupe's Avatar
tried it on a portable dvd player input today and no picture .It must be a defective cam .Thanks
chinee
Jun 10, 2024 07:48 PM
mjfenix
Aug 17, 2017 05:49 AM
