How Many Fuse Boxes?
Old May 19, 2008 | 06:47 PM
Mjohn's Avatar
Just wondering how many fuse boxes do we have in our G's ?
I know of one beside the dead pedal on the driver side..
Is there two fuse boxes under the hood additionally..
I have heard of a box 'behind' the battery but at first look I didn't see anything like that..
Is this fuse box on all model G's?
Old May 19, 2008 | 10:36 PM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
I think there are only 2.
The IPDM E/R located near the driver's dead pedal and the Fuse Box Junction Box (J/B) located behind the battery.
<a href="http://imageshack.us"><img src="http://img246.imageshack.us/img246/5359/fuseboxaz7.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a><br/><a href="http://g.imageshack.us/g.php?h=246&i=fuseboxaz7.jpg"><img src="http://img246.imageshack.us/img246/5359/fuseboxaz7.79a9d73333.jpg" border="0"></a>
<a href="http://imageshack.us"><img src="http://img246.imageshack.us/img246/7151/ipdmfp8.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a><br/><a href="http://g.imageshack.us/g.php?h=246&i=ipdmfp8.jpg"><img src="http://img246.imageshack.us/img246/7151/ipdmfp8.35d7de12f9.jpg" border="0"></a>
<a href="http://imageshack.us"><img src="http://img441.imageshack.us/img441/3149/fuseboxjbjz6.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a><br/><a href="http://g.imageshack.us/g.php?h=441&i=fuseboxjbjz6.jpg"><img src="http://img441.imageshack.us/img441/3149/fuseboxjbjz6.c09c557950.jpg" border="0"></a>
hope this helps....
doc
Old May 19, 2008 | 11:29 PM
Boston's Avatar
+1 on what Doc posted. One to the left of the dead pedal and the other by the battery. Pull the entire battery cover off and not just the terminal access panel and you'll see it.
Old May 20, 2008 | 04:32 PM
Mjohn's Avatar
ahhh perrfect Sweet diagrams
That one behind the battery is very covertly positioned..
Old May 20, 2008 | 07:09 PM
Gilley's Avatar
There is also a fuse on the positive battery terminal block.
Old May 23, 2008 | 10:50 PM
G35ANSTA's Avatar
Does anyone here know where the fuse for the headlights and rear tail lights are. I accidently blew a fuse that took out both my heads and rear lights. My reverse, break lights and turn signals are working. I checked both fuse boxes and the labels do not clearly identify these fuses or fuse?
Old Dec 5, 2020 | 05:32 PM
efthimiz's Avatar
Interior fuse box the same for all g35 coupe models?
I have an 07 6mt coupe with a faulty interior fuse box and need to replace it but want to make sure if they vary from the 03-07 years. I cannot find info if they are specific to automatic or manual and year to year.
Old Dec 5, 2020 | 05:36 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
They vary based on the PACKAGE for the vehicle, there will be pins installed in the ones for sunroof and such.
If you get the wrong one you can take it apart and repin, usually just takes a small precision flat screwdriver to install pins. You can use your existing Fuse Block - J/B as a donor for pins.
I've never seen a faulty FB-J/B though are you SURE that's the problem? You can usually fix anything wrong with the fuse block just by disassembling it and tracing out circuits, solder if necessary, repin if necessary.
Old Dec 5, 2020 | 05:49 PM
efthimiz's Avatar
It may be a pin issue then because I need to use a flat head screw driver to flex the fuse box if it does not come on after turning on the car. Specifically, its the following items that initially do turn on: gauge, radio, air system which all feed off that the box.
It's such an awkward location of the car to try troubleshooting the issue. Further suggestions now knowing more of what I am dealing with?
QUOTE=cleric670;7199563]They vary based on the PACKAGE for the vehicle, there will be pins installed in the ones for sunroof and such.
I've never seen a faulty FB-J/B though are you SURE that's the problem? You can usually fix anything wrong with the fuse block just by disassembling it and tracing out circuits, solder if necessary, repin if necessary.[/QUOTE]
Old Dec 6, 2020 | 11:31 AM
cleric670's Avatar
BANNED!!!
Exactly what year and what chassis are you working on?
EDIT: Losing that many systems all at once usually means you cooked one of the main fuses in the fusible link holder. It bolts directly to the battery and has about a dozen large fuses that send power off to various parts of the fuse blocks.
Old Dec 6, 2020 | 11:35 AM
efthimiz's Avatar
07 coupe
Old Dec 6, 2020 | 11:37 AM
cleric670's Avatar
BANNED!!!
Start with fusible link holder slot "D", it's a 60 amp, pretty sure that one does all your driver information stuff. Check them all though, disconnect the battery, remove each fuse from the fusible link and inspect for damage. Sometimes they cook on the BACK of the fuse and damage the holder. The holder is an off the shelf item at almost every auto parts house.
hbrew
Jan 17, 2012 07:05 PM
ebuy929
Nov 22, 2005 10:51 PM
amthar
Sep 21, 2005 07:33 PM
governor
Dec 21, 2004 12:44 PM
Will_blueprint
Jul 10, 2004 09:38 PM
