6x9 question
6x9 question
I have a nice set of Eclipse 6x9's that I installed in my integra shortly before purchasing my G, would throwing these in my G increase the quality of sound or am I better off with what came with it. I have an 05 coupe with bose. Thanks!
Ok, I will just wait until I get my Diamond Audio Hex Pro component sets, I think I am going to run two, replace the fronts and the mid ones, only i'll add the tweater in the pillar, Ill use some Diamond Audio 6x9's as well, should sound clean..
You also need to consider that the stock Bose 6x9's are used as woofers only, (there is no midrange or treble in the signal going to them) so if you replace them with coaxial type speakers I would bet that they will sound worse than the stockers.
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
