what amp gauge wire should i use..
Old May 22, 2008 | 10:37 PM
nyqueenz's Avatar
I have one Ref 1052 10" runing off a Ref 1600a amp @ 600 watt peak
should i do 4 gauge or 8?
Old May 22, 2008 | 10:44 PM
DHCrocks's Avatar
4ga.
Old May 23, 2008 | 12:06 AM
pete's 03svt's Avatar
8 will work fine, but I would use 4 so if you ever upgrade to a bigger amp you don't have to rewire it.
Old May 23, 2008 | 01:51 AM
Meatshackle's Avatar
Deep Sea Moderator
^+1
8 will work but 4 will be much better and leave you room to grow.
Old May 23, 2008 | 08:05 AM
DHCrocks's Avatar
The current draw for 600w is 42.8A at 14.4v (I=p/v, 600/14.4) assuming a 60% efficiency of the amp gives peak current draw of 71.3A.
71.3A through 15' of 8ga is a 1.4v drop, same through 4ga is 0.5v drop. as a general rule 0.5v drop is acceptable. I would go for the 4ga, it's more suited for a 600w-1000w amp. I only like to use 8ga on amps in the 300w range. Anything over 1000w should use 1/0.
Old May 23, 2008 | 09:39 AM
JEAThirty5's Avatar
http://nedm.tunl.duke.edu/~yq/resear...Gauge_Size.htm
Old May 23, 2008 | 11:55 AM
JessNherG's Avatar
As people have said 8 is fine but go with 4 gauge. I assume you are mainly asking b/c of budget constraints.
Old May 23, 2008 | 12:37 PM
trey99ek's Avatar
Price is not that much of a difference if you think. $10-15 maybe for the 4 over the 8. Look into the long run. If you ever want to upgrade just get the 4ga now.
Old May 27, 2008 | 11:22 PM
CanBum's Avatar
I went with 0 guage and ran a wire for every RCA cable my deck had. Wiring that car is a pain in the a$$. I only wanted to do it once no matter what I wanted in there later. Might cost a few extra now, but later on it may save you time and frustration.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
g.spot
May 9, 2016 10:54 PM
9tray turbo
Sep 29, 2015 10:22 PM
