07 Coupe Ipod connect.... help
I have read a few thread on this site and I'm very confused
, a lot of the units that connect your iPod to the factory stereo work up till the 06 model but not the 07. Can someone please point me in the right direction? I want to connect my iPod to my factory stereo, I want the iPod in the center console, and I want it to charge while plugged in, I want the text to display on my stereo, have some control access with the steering wheel, and have access to change between artists from the iPod itself. I know thats a lot to ask for but theres got to be something out there that can do this with a factory setup. I have NAV but no factory satellite radio. Please help... I can't live without my music. I have the 2007 coupe with NAV.
The iPod adapters should work with your 07. I'm not aware of anything changing between the models that would prevent you from doing so.
I think the only adapter that will display on the OEM HU is the Nissan iPod adapter.
+1 The OEM Nissan interface will do the job. USA-SPEC PA11-NIS will do the job too except text display. Both of these units can have the ipod cable come out of the center console, just depends where you install it and the cable lengths.
Yep, me too. I'm dying to hear from *someone*, anyone, who's successfully installed the USA SPEC PA11-NIS in a 2007 Coupe. Or sedan. Or whatever.
I've got an '07 G35 Coupe, with Sat, no Nav, and I'm dying without a hard-wired iPod... I'm happy to go without the Sat capability if need be, and I'm not bothered about track names/artists not displaying on screen. I'm just about to the point of just buying the USA Spec unit and trying it out. I can't think of any reason why it shouldn't work in the 2007's, but the manufacturer makes a point of saying that compatibility only goes up to the 2006 models. Haven't heard of anyone succeeding or failing yet either with an '07...
I'll let you know how it goes if I end up pulling the trigger.
Originally Posted by acr
What's different about the 07 coupes stereo?
Ok--so I pulled the trigger and had the USA SPEC PA11-NIS unit installed a few days ago in my '07 coupe. I couldn't be happier with the results. Anyone who's considering this should do it immediately. I had the installer drill a small hole in that spare Nav compartment. The iPod plug sits in there as does the iPod itself, maintaining a clean, stock appearance. The sound quality is awesome--just what I was after. What shocked me, though, was that I have not only Direct control of the iPod itself, but that I can also skip forward/back using the steering wheel controls. That was a totally unexpected result based on what I'd read previously. I had to sacrifice my Sat radio, and no artist/song info on the factory unit, but who cares?? A total win.
bump i just bought a 2007 g35 coupe 6mt with nav and everything...i have a blackberry and everyone keeps telling me to get an ipod in the forums, is there a "work around" getting music goodness and some level of control via the g and some level of info on the screen...like, no one has invented something for this ? crazy i just got my g tonight.....its the only dull point of the night
so the ipod thing works...? just no info on the screen...and you cant change playlists, artists, etc(unless you do it via the ipod)....but i guess i would just make a G playlist and cruise around with those songs, right?
there is NO difference in the 07 head units. any of these solutions work for g35 coupes.
the factory Nissan ipod interface unit will give you basic text display on the Bose unit (NOT the NAV display) and controls from Bose and steering wheel as well. USA Spec is another option if you want to control it from head unit/steering wheel - and is cheaper and easier to install.
you last option is the PAC unit. little more basic as it doesn't give you display or the ability to control from head unit/steering wheel but is cheaper and you CAN have factory SAT at the same time. that's the option i went with - more info on my solution on my site myG35mods.com.
djreinx
Engine - Electrical
Dec 10, 2015 01:48 AM
