need help with pdx 1.1000 install!!
Old Jun 12, 2008 | 11:28 AM
GD-Up's Avatar
Hi all!
I just put in my pdx 1.1000 to power my two kicker subs. Now, I am no car audio install genius by FAR!!..so I need some help.
I wired the subs into a 4ohm load as per diagram and that left me with two negative leads and two positive leads that i twisted together to make one positive and one negative for my speaker input to the amp.
I am getting power to the amp and the subs are working up to a certain volume, once I go past 7-8 on volume there is a thud, then no bass. I have to turn off the car and restart it then I have bass again untill vol 7ish.
I don't have a cap or anything and this is draining mad power from the rest of the car....
Any ideas of what I am doin wrong???
Old Jun 12, 2008 | 12:43 PM
Gilley's Avatar
What Kicker subs do you have and if they are dual voice coils, what is the ohm rating (impedance) of each voice coil?
The PDX 1.1000 is a monoblock amp that has two plugs to connect the speakers. You can use one plug for each speaker.
Old Jun 12, 2008 | 01:05 PM
Meatshackle's Avatar
Deep Sea Moderator
Aren't the pos and neg wired in parallel inside?
Old Jun 12, 2008 | 09:22 PM
GD-Up's Avatar
I have 2 10" comp VR's the Kicker site says they are 2/4ohm DVC....whatever that means.
I get mad signal discharge every time i turn the car on too!...but that was there before from the other **** "professional" install I had done.
Old Jun 12, 2008 | 09:24 PM
GD-Up's Avatar
Not sure what that is supposed to look like
Old Jun 12, 2008 | 09:27 PM
Deep Sea Moderator
Your amp manual would tell you if it's wired that way. Most higher end monoblocks are wired so you don't have to wire your speakers together outside they just plug into the amp individually.
Old Jun 13, 2008 | 10:32 AM
Gilley's Avatar
Your problem is the way you have wired the DVCs. Your amp is getting a 1 ohm load, so it will shut off.
Wire the DVCs on the subs in series and then the subs in parallel form so you'll provide the amp with a 4 ohm load.
Or you can wire the DVCs of the subs in series and connect each sub to one of the Alpine speaker connector plugs.
Old Jun 13, 2008 | 12:21 PM
GD-Up's Avatar
Hi Gilley, do you have a diagram or know where I can get one to set up the DVC in seriese and the subs parallel (your first set up)?
Old Jun 13, 2008 | 11:28 PM
Gilley's Avatar
Connect a wire of the negative from the first voice coil to the positive of the other voice coil. Then connect the empty + and - terminals of the sub to the amp. Repeat for the other side.
Old Jun 15, 2008 | 02:05 AM
GD-Up's Avatar
Gilley, I hooked it up as you said, and it worked good!..seemed to be out of phase for a bit, but that was cuz a wire shook loose...so it worked great for 5 mins....then I don't know what happend but now there is no signal going to the subs. I though it was a loose connection on the speaker input leads... but that didn't help. I thought I may have messed the amp, so i put another one in...still nothing. All fuses a fine...is there anothe fuse I could have blown...(in the deck?) or should I just give up now.
Old Jun 15, 2008 | 08:48 PM
Gilley's Avatar
If the amp is receiving a signal and is working properly, but no sound is coming out, then it is probably a problem with your sub. It is possible that you wired one voice coil out of phase.
Old Jun 16, 2008 | 12:04 AM
Rocket1991's Avatar
It sounds like your wiring is still messed up. I installed a PDX 1.600 with 2 JLW3's and the amp kept going into protect mode and shutting down after raising the volume. I had to restart the car every time to get the amp back. You should be seeing a red light on the side panel, that means its in protect mode. My problem was that one of the subs connections was not seated all the way and kept grounding itself on the chassis. Check the cabling again, good luck.
Old Jun 16, 2008 | 12:23 AM
GD-Up's Avatar
Thanks Rocket! I will check the sub wiring again. The amp still lights up blue, never had a red light yet.
G-MAN (CANADA)
Canada
Sep 7, 2015 03:51 PM
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
