Need help with wiring DDin brake override
Old Jun 20, 2008 | 12:27 PM
tdelta1000's Avatar
Need help with wiring Double Din brake override
Hello G Drivers,
For those of you with double din radios with reverse camera capability, how did you wire for the brake override and reverse switch to active the camera? Any information would be helpful.
General Info:
Vehicle-'04 Sedan
Radio-Jensen VM9022
Thanks.
Old Jun 23, 2008 | 10:05 AM
tdelta1000's Avatar
After some research I found the Brake Bypass Code for the Jensen vm 9022. I also found the wire that would cause the reverse camera to activate when the car put in reverse.
Old Jun 23, 2008 | 10:09 AM
Hi-TechG35's Avatar
Just ground the parking brake wire and that should do it.
boostelevator
Brakes
Oct 5, 2015 08:56 AM
AuAltima3.5
Audio/Video/Electronics
Sep 12, 2015 08:21 AM
Hawk196
Sep 10, 2015 10:37 AM
NJ6MT
Sep 10, 2015 08:40 AM
mtlruss
Lighting
Sep 9, 2015 07:44 PM
